EGR delete?
Old Jun 7, 2010 | 10:11 PM
95_TA_USMC's Avatar
Default EGR delete?
anyone done this? my egr tube is gone with the headers being on the car, so it would make since to delete it all together right? anyone had problems with takin it off? let me know, in the middle of the cam swap right now and was just wondering! ill get pics up soon...
Old Jun 8, 2010 | 09:14 AM
brucer's Avatar
i deleted my egr system..
i also got an ses light, and threw the code for egr circuit failure.. you can have it tuned out.
Old Jun 8, 2010 | 09:43 AM
lt11994's Avatar
I deleted it as well and got an SES light. However all I did was plug in the EGR solenoid to the harness and tucked it away and the SES light shut off. Its a temporary fix until I get it tuned but it worked You will need block off plates. I bought mine off of eBay for $12.
Old Jun 8, 2010 | 10:14 AM
94-z's Avatar
Just did this a few weeks ago just pull the solenoid off and the tube off put block off plates where they use to be. Did you also remove you AIR system?
Old Jun 8, 2010 | 11:12 AM
litch2004's Avatar
You can delete the air system as well. Some get away with removing everything and just leaving the fuse in. Some get a ses light some don't.
Old Jun 8, 2010 | 04:20 PM
Hellbentz's Avatar
Did it not to long ago. Got an SES light but had it tuned out of my PCM. It's very simple. Get some EGR block off plates and some silicone to seal it and your golden. Took me about 20 minutes. It sucked more just getting your arm back there with it being so close to the cowl.
Old Jun 8, 2010 | 04:26 PM
brucer's Avatar
i deleted my a.i.r. system also , didnt get an ses light or any codes for it.
