Engine Removal!
Old Jun 9, 2010 | 09:52 AM
BuckeyeZ28's Avatar
Default Engine Removal!
Today is finally here, the day I finally get to take my LT1 out! Since Ive never used a cherry picker before I figured i better ask before I break ****. What is the best way to attach the chains to the engine with the heads still on? Also, how many bell housing bolts are there on the top/bottom?
Old Jun 9, 2010 | 10:26 AM
monster81's Avatar
i guess there are 6 bolts (3 on each side,right and left of the bell house) and 2 dowel pins
Old Jun 9, 2010 | 10:35 AM
BuckeyeZ28's Avatar
Dowel pins? where are those located?
Old Jun 9, 2010 | 10:55 AM
old93camaro's Avatar
the pins hold the bellhousing to the engine .. you dont take those out. it just holds it there.. and you can pick the engine up from the heads but dont leave it over night hanging from them....
Old Jun 9, 2010 | 11:27 AM
BlackBird87's Avatar
Why dont you drop it out of the bottom
Old Jun 9, 2010 | 12:12 PM
monster81's Avatar
i was about to ask the same Q, but didnt want to start a thread war lol
Old Jun 9, 2010 | 02:24 PM
1toofastlt1's Avatar
im going to drop mine out the bottom soon. ive never done it before does anyone have some pointers?
Old Jun 9, 2010 | 02:27 PM
RamAir95TA's Avatar
http://www.michiganspeed.com/enginepull/index.html
Old Jun 9, 2010 | 02:39 PM
stryker1320's Avatar
Better plan an extra 2-3 hours more than what you think it will take, especially if the engine has never been out before. These cars are starting to get some age on them and rusty bolts and nuts can be a real bitch to work with! Might wanna grab a couple of your preferred alcoholic beverage to assist you too! Lol
Old Jun 9, 2010 | 03:46 PM
JB_97ws6TA's Avatar
Originally Posted by RamAir95TA
I used this method and it worked great, my car is a 97 so I was not able to loop the chain through the frame horns and I did not like the idea of using rad support so I had the car on jackstands in the front, popped the k member and struts loose, lowered the assembly with a jack then used a chain between the strut towers and lifted the car the rest of the way.
Old Jun 9, 2010 | 06:36 PM
Speed Density's Avatar
hashtagBMW
I used to be PRO-out the top but now that I've done it out the bottom Ill never do the top again. If you have a picker, tow straps and a dolly for the engine then do the bottom. It will take you 4hrs maybe.
Old Jun 9, 2010 | 06:48 PM
scj's Avatar
scj
out bottom ftw...
Old Jun 9, 2010 | 07:05 PM
projectX's Avatar
Agreed on bottom. Less time and headache
Old Jun 9, 2010 | 08:17 PM
I have done this both ways, and if the heads have to come off anyway, I would much rather pull it out the top! I know this is not the preferred or favorite method, but it is my opinion. And yes I have full capabilities, room, and tools to do it both ways.
