Post Up Your Single Plane PICS!
http://www.racingjunk.com/Intake-man...-Manifold.html
You can either run SBC heads converted to reverse cooling with SBC intake, convert the bolt spacing on SBC heads to LT1 for an LT1 intake(not really recommended), or convert the LT1 intake to SBC bolt spacing to run any SBC intake on an LT1 head.
If using LT1 heads, you can convert either the intake or heads to SBC style.
Shaved the water neck, converted it, welded in injector bungs/fuel rail mounts, fully ported and clover leafed it, and cut out the lifter valley portion and replaced it with a Carbon Fiber heat shield.
It is a work of art inside and out!
Not sure if its something I would do myself if I was converting an intake - IMO its probably more for looks then performance, and that is a lot of money and work for something that I doubt is actually worth much unless you hot lap like crazy. I would have to dig it out of a box to take more pictures, but you can see it pretty good in this old picture:
. That was back in late July and since then I have been able to get more done on getting the 409 put together and ready to go in than months and even years before. (Even though I was still sick for most of the weeks since.) I credit it all to taking time to write down a plan/budget and strictly sticking to it. Each and every part (or machine shop service) was listed out along with each part I could sell to offset the expenses. I even listed dates that I hoped to sell or buy each thing by. It has worked out GREAT!!
Hoping by the end of the year to have a 474"-482", solid roller W motor running by the end of the year....almost entirely funded by spare parts I would have probably never gotten around to using.
