A couple of quick questions for you guys..
so you did a cam swap? do you remember the numbers? that could have possibly thrown off your computer and might be why your noticing other issues.
if your pulling the heads off you have 2 choices.. one get them completely redone by a company or buy a set of aftermarket heads such as AFR's..
But, look into LE kits too.. and you might need to go through the car before you break something else.
Yes, CC 503, The cam down is all rebuilt. No work on heads or intake beside a CAI. Im on a budget so im taking them to Kimm Barr Racing. I think ima go ahead and get the ported and polished...is it worth the extra money?
what do you mean go through the car? i dont have any intentions on breaking anything else?
If you pull those heads, spend the money to have the springs setup correctly, have a valvejob done and put new seals on them.
But ive been getting that code way before my flexplate cracked. So therefore what else could be throwing that code? I've always thought that since i have that cam in there the engine thinks it's missing..idk if thats the case though..
any help will be much appreciated!
random mulitple cylinder misfire
I pulled the air pump recently. Also capped off all A.I.R fittings (i believe thats what it called. Like on my pacestters the fittings are capped off.
