A couple of quick questions for you guys..
At 130,000 miles should i be assuming that my valve seats are wasted?
How long do our stock torque converters last?
Valve "seats" aren't a normal wear component. Perhaps you mean valve "seals?"
A stock torque converter will last as long as the fluid.
My car recently has been going down hill on power, yet i still need a tune.
bro all of that is new, when i pulled the engine all ignition **** was replaced, with quality stuff too..
Im running cc 503 with LT pacesetters. Many people tell me i need to get it tuned but i feel like the computer wont just keep going down hill. So therefore i assume its somewhere else. When we put the engine back together we didnt have the money to even touch the springs
I just cracked a flexplate so last night i pulled the tranny and we ordered new springs to accommodate w/ my cam. Seems to me i should go ahead and pull those heads of and get him grind down, ported and polished. Plus i have a nasty oil leak coming from the opti we assume but then again its sprayed all over the bottom of the water pump...is that possible?
Thanks for any advice in advance!
Get some cheap springs on her ASAP! Isky D235 springs are cheap and require ZERO machine work, and Im sure a hundred other people will tell you the same on here.
so you did a cam swap? do you remember the numbers? that could have possibly thrown off your computer and might be why your noticing other issues.
if your pulling the heads off you have 2 choices.. one get them completely redone by a company or buy a set of aftermarket heads such as AFR's..
But, look into LE kits too.. and you might need to go through the car before you break something else.
But thats great. I got the beehive ones that work perfect with my cam!
and 130k is just broken in for an LT1!
