Hot cam in non factory roller block
Old 06-15-2010, 09:27 PM
69x22's Avatar
Default Hot cam in non factory roller block
I want to install a LT4 hot cam in a engine that was not a factory roller engine. Can I use aftermarket roller lifters? Is there anything else I am missing on this swap?
Old 06-15-2010, 11:03 PM
pyro719's Avatar
Cam button so the cam dosnt walk in and out of the block. Id just get a factoy roller block
Old 06-15-2010, 11:18 PM
69x22's Avatar
Default Cam
The engine is already a nice build, it would make for a expensive cam swap.
Old 06-15-2010, 11:23 PM
gregrob's Avatar
If its a "nice build " why do you want to use the hit cam?
Is this a gen 1 block?
Old 06-16-2010, 01:07 AM
69x22's Avatar
Default Engine
The cam that is in the car is too radical and not something you would want to drive out of town and put some miles on. My 57 has the hot cam in it and I like everything about it. The block is around a 1982 engine.
Old 04-19-2012, 09:48 AM
king-918's Avatar
Having the same problem I have a pre 80s block and I'm using a lt4 hot cam but the timing set does not match up? Any help?
Old 04-19-2012, 02:18 PM
gjohnsonws6's Avatar
If it is a nice build as you say,then it should already have a roller in it,why not get a retro cam,if not I would get a retro kit
Quick Reply: Hot cam in non factory roller block
