LT1 fuel pump issues
Old Jun 16, 2010 | 07:29 PM
am_muscl's Avatar
Default LT1 fuel pump issues
So I posted this up in the fuel & injection section but hopefully I can figure this out soon.
I just replaced what I thought was a bad fuel pump with a new stock replacement.
I plugged everything in and before I bolted it down I wanted to make sure that I could at least hear it prime....I got nothing.
I checked all the fuses and all the fuses are good and I check the connectors going back to the fuel pump and it IS getting power.
I'm not sure what else could be wrong and if I don't get it fixed and driveable by July 1st the car is going to be towed away.
PLEASE HELP!!
Old Jun 16, 2010 | 07:44 PM
transmaro93's Avatar
there is a relay... they dont usually go bad but its worth a shot to check it out... it believe its under the left kick panel down by where your left foot would be... and check every fuse sometimes fuses that dont say fuel pump may power it... also check your grounds
Old Jun 16, 2010 | 08:02 PM
am_muscl's Avatar
i know this sounds like a total newb question, but I don't know a whole lot. How do you check all the grounds?
I have this tester I got from Harbor Freight but to be honest I'm not 100% sure how to read/use it. It's supposed to measure AC/DC voltage and all that but again I'm not really sure how to read it.
For some reason I have a feeling a ground is causing my issue though
Old Jun 16, 2010 | 08:05 PM
SoxXpupPeT's Avatar
check for pressure at the rail
