Need some advice
Old Jun 19, 2010 | 03:43 PM
RED PUNISHER Z's Avatar
Default Need some advice
ill be driving my car its a auto 95 z28 and say around 40-50 ill have my foot on the gas pedal like 20% just cruising and if i want to speed up ill give it a bit more gas say 40% but nothing it does not down shift ill have to give it about 60% then it will drop gear and go what can is it the transmission or the torque converter this happens at any speed
Old Jun 19, 2010 | 03:49 PM
JB_97ws6TA's Avatar
the transmission is shifted by the pcm and there is a tps vs rpm table (if I remeber correctly) that shifts your transmission. If you would like it to shift with less throttle you are going to have to get it tuned. I don't understand why you would need to drop a gear at 40% tps anyhow, if you wanna go you gotta put your foot down. Quit pussyfootin around and give it some gas
Old Jun 19, 2010 | 05:09 PM
hahaha.... na its not that i want to drop gear faster it that when i drive my friends 95 z28 it has way better response than mine like the tranny feels more a live and when im in my car i can heat up my 245' tires and stall the car and it will hook like if i had slicks on and in my friends car his goes all over the road so i was thinking it had to do with the transmission or the torque converter
