need help with pcm communication error!!!!
Old Jun 24, 2010 | 08:26 AM
97 SS LT1's Avatar
Originally Posted by moehorsepower
there is only 7 wires that are needed to communicate to the pcm, I have the schematic at home, I can look at it when I get there tonite unless someone here has the pin numbers of those 7 wires, actually only one is the data wire, two were power wires, and I think the rest were grounds....
Thanks! i was looking back at what he posted and it looks like #9 on the plug goes straight to the PCM for data...so if we check it for opens and shorts and it checks out good then it narrows it to the PCM...correct? just not sure what pin to check on the PCM plug?
Old Jun 24, 2010 | 08:55 AM
moehorsepower's Avatar
Should be, you can use an ohm meter and ohm out the wire from the ALDL port to the harness, again, I can tell you later, I know the hots were like RED 18 & 22, I think the data blue 1 ect, I don't want to give you the wrong info now..
Old Jun 24, 2010 | 08:59 AM
97 SS LT1's Avatar
Thanks Moe! If you don't mind looking when you get home i know he would appreciate it!
Old Jun 24, 2010 | 04:47 PM
OK here they are:
Grounds:
Blue 1
Red 18 & 22
Data:
Blue 30
Hot:
Black 15
Black 30
Black 31
Old Jun 24, 2010 | 05:39 PM
mean_greenZ's Avatar
OK here they are:
Grounds:
Blue 1
Red 18 & 22
Data:
Blue 30
Hot:
Black 15
Black 30
Black 31
Thanks Moe!! I had my PCM tested at a local speed shop and they could connect to it and upload and remove the tune. So thank goodness it's NOT my pcm! I will test those wires and hopefully find it.
Do I need to test all 6 or just the Data Link wire?
Old Jun 24, 2010 | 08:41 PM
97 SS LT1's Avatar
OK here they are:
Grounds:
Blue 1
Red 18 & 22
Data:
Blue 30
Hot:
Black 15
Black 30
Black 31
Thanks moe!!
