Fabed Alum Valve covers
Old Jun 24, 2010 | 11:54 AM
Whyrun's Avatar
Default Fabed Alum Valve covers
Does anyone know of a company who makes a good set of aluminum fabbed valve covers for a reasonable price, they will be bolted to a set of trickflow center bolt head's. I found some at Jegg's for $161.00 but they were made by Spectra however I haven't heard anything good about thier products in the past, so I thought I would throw out a flag and see what you guy's recommend, thanks.
Old Jun 24, 2010 | 12:26 PM
1badzee's Avatar
I love my Cantons, FWIW
Old Jun 24, 2010 | 12:27 PM
Alteredspeed's Avatar
Default Valve Covers
The only ones I know of is the Canton ones. Some guys had trouble with oil leaks but if you use the right gaskets and some silicone. They work fine.
Old Jun 24, 2010 | 01:15 PM
Whyrun's Avatar
I was originally going with the Cantons, but the dang things are so expensive $$$. But if that's all that's out there I will have to bite the bullet.
Old Jun 24, 2010 | 01:45 PM
I8ASaleen's Avatar
for $30 more you could have Cantons off of ebay.
Old Jun 24, 2010 | 06:48 PM
suicidal racing's Avatar
http://cgi.ebay.com/ebaymotors/SBC-C...item3cae44d395
Old Jun 24, 2010 | 07:12 PM
kierstyn's Avatar
To run the ones you speak of you would have to relocate your alternator. If you are going to keep it in the stock location get the cantons.
Old Jun 24, 2010 | 09:23 PM
AChotrod's Avatar
Originally Posted by suicidal racing
Nice Im gonna buy those! And yes my alt is relocated!
Old Jun 24, 2010 | 09:55 PM
1993 z28 f1's Avatar
Hey:
Just do NOT ever overtighten the Cantons. I use to have them and after they got a healthy tightning they started to leak. A problem many have had with them. Use good gaskets and only tighten tight enough to be snug and stop any leaks, no more. Better a little loose to start with, than too tight, as after they have been overtightened they are not the same.
Dub
When In Doubt Do Without
Old Jun 24, 2010 | 10:18 PM
Valkyn's Avatar
Dumb question but can you reloc your alternator while you still have AC?
These are $100 bucks and have the notch for the alternator...do they look like they would clear 1.6RRs?
http://cgi.ebay.com/ebaymotors/SB-Ch...item19bd4e2463
edit- eh i guess they are stamped not fabbed
