Rear end help needed
Old Jun 24, 2010 | 10:34 PM
95ZR28's Avatar
Default Rear end help needed
Well my rear end in my camaro is now trash!!! Its broke... I have a friend with a Ls1 camaro rear end with 3.42's in the rear for 150$ What is diff??? I know brakes are different. But what else do i have to change??? Or is it worth the hassel? Any help would be great
Old Jun 24, 2010 | 10:40 PM
SoxXpupPeT's Avatar
well itd be worth it to have a rear back in your car! but you wont have ABS... and the brakes are different.. idk what would be needed to hook them up tho...
Old Jun 24, 2010 | 10:42 PM
95ZR28's Avatar
Well if i switch the brakes and rotors and and maybe the axles??? and the could I use my abs sensor in the rearend??? I just dont know thats why i came to you guys
lol
Old Jun 24, 2010 | 10:48 PM
SoxXpupPeT's Avatar
lol
ls1 cars have 4 channel abs so the axles have the reluctor rings on them. youd have to change the carrier to a 3 channel carrier
Old Jun 24, 2010 | 11:07 PM
95ZR28's Avatar
So Is it worth the time and money??? do i need the abs?
RamAir95TA's Avatar
Do you think you need ABS?
Old Jun 25, 2010 | 02:12 PM
95ZR28's Avatar
What does it do? You tell me do i need it or not?
Old Jun 25, 2010 | 02:40 PM
Slow94Formula's Avatar
ABS = Anti lock Brakes. Do you drive in the winter? That's about the only time I would ever use my abs...
Old Jun 25, 2010 | 02:43 PM
merim123's Avatar
i ditched my abs a long time ago. pedal is much better, easier access in the engine bay too. Can't drive this thing in the winter anyway.
Old Jun 25, 2010 | 04:03 PM
shbox's Avatar
If the LS1 rear has 3 channel ABS (no traction control), then it will swap right in (LS1 brakes and all). You will need the the e-brake cables from the LS1 car. ABS will work.
Old Jun 26, 2010 | 12:15 AM
01ssreda4's Avatar
^^^^He's right. Basically a ten bolt is a ten bolt is a ten bolt, with a few details aside. So yes you should get it.
Old Jun 26, 2010 | 12:56 AM
BlackBird87's Avatar
forgetting about cruise control, i use it daily
