Oil pan!
Old Jun 27, 2010 | 02:06 AM
z28boycali's Avatar
Default Oil pan!
hey my Chevy Fam
1997 Camaro z28
My oil pan seems to be no good its leaking oil badly!
how hard is it to change it?
Old Jun 27, 2010 | 02:09 AM
RamAir95TA's Avatar
For you it will be pretty difficult. There are a few threads documenting the procedure - a search will yield tons of info.
Old Jun 27, 2010 | 03:03 AM
letsrun97z's Avatar
You sure it's the pan and not the rear main seal?
Old Jun 27, 2010 | 09:44 AM
speed_demon24's Avatar
It's actually alot easier to get the stock oil pan out than most people say. Lower the k-member so its just hanging on by a few threads on the bolts and jack up the motor as much as you can and it will slide right out.
Old Jun 27, 2010 | 01:21 PM
ElkySS's Avatar
its more of a bitch with the stock exhaust in it
Old Jun 27, 2010 | 02:19 PM
z28boycali's Avatar
mann my Car and oil wreck! it leaks from the timing cover from the rear main seal and the oil pan!
if it was you car with this problem which of the 3 leaks you would fix first?
how much am i looking to get these leaks fix in a shop?
can anyone give me and estimate of what im looking forward to pay?
Old Jun 27, 2010 | 03:18 PM
97lt1camaro's Avatar
$968.89 roughly.
Old Jun 27, 2010 | 03:39 PM
z28boycali's Avatar
damm well gotta do what i gotta do for now and make some money!
Old Jun 28, 2010 | 03:42 PM
flatbird's Avatar
Originally Posted by 97lt1camaro
$968.89 roughly.
Ha...roughly exact...
Old Jun 28, 2010 | 03:46 PM
I8ASaleen's Avatar
Disconnect the stock y-pipe, take off the starter, remover the motor mount thru-bolts, jack up the engine as high as possible, lower the bolts that hold the k-member in place, remove the oil pan bolts, hope to God you can get it out.
Old Jun 28, 2010 | 03:49 PM
zbomb5610's Avatar
i have slightly skimmed through a few of this guys threads, is it safe for him to work underneath a car?
Old Jun 30, 2010 | 09:21 AM
flatbird's Avatar
I was working with the car on stands when I was 15...just don't be a dumbass
and you'll be fine...
Old Jun 30, 2010 | 10:36 AM
defaultexistence's Avatar
I'LL Give you $1000 for it as it sits
Old Jun 30, 2010 | 05:13 PM
leadfoot4's Avatar
I agree, but if it's an A4, you don't even have to drop the k-member.....
Old Jun 30, 2010 | 06:51 PM
I8ASaleen's Avatar
Most of the time, but I have seen some exceptions to this. Even A4's can need extra clearance when the engine/tranny is jacked up. Mine gave me so much hell (I'm an M6) that even when the k-member almost all the way out and the engine as high as possible it still took some hard pulling to remove it.
