Spark plug replacement....help!
Old Jun 29, 2010 | 08:47 PM
black heartbeat's Avatar
Default Spark plug replacement....help!
ok so I have an lt1 trans am with hooker super competition long tubes and I can't seem to find it humanly possible to remove the last two passenger side spark plugs (closest to the firewall) without removing the headers themselves! Am I missing something here?
Old Jun 29, 2010 | 08:53 PM
SexyTransAm's Avatar
having 2 elbows would help
Old Jun 29, 2010 | 09:02 PM
dubga's Avatar
Can you pull the starter and get to them? Helped me with #8 (closest to the firewall), but I didn't have long tubes.
Old Jun 29, 2010 | 09:10 PM
defaultexistence's Avatar
change them from under he car, move the starter if needed.....................seriously
Old Jun 29, 2010 | 09:14 PM
the open end will get caught in between a bend in the header and the socket when I start to back out and theres not enough space for a ratchet on number 8 and number 6 is impossible to fit anything in and have it line up it seems. I just spent over four hours on this and it's not like I'm an idiot. I mean, I rode the short bus for a few years and I was the only one in class wearing a helmet but....thats besides the point
Old Jun 29, 2010 | 09:16 PM
oh I should mention I'm working in a gravel driveway with ramps, hence my lack of being able to do a lot of work from under that car
Old Jun 29, 2010 | 09:20 PM
Gojira94's Avatar
Try the spark plug socket with a combo wrench (open end) from up top. I did mine a couple weeks ago on ramps and stood on a small cooler to reach #8 this way. Same strategy may work from the bottom on #6.
Old Jun 29, 2010 | 09:25 PM
Hellbentz's Avatar
I have mid tubes, but i found it way easier to do those from under the car. You can get a box wrench on them, or use an open ended wrench with a spark plug socket like mentioned above.
Old Jun 29, 2010 | 10:02 PM
thanks guys I appreciate the advice I'll give it a shot, I should be done by 2 o'clock in the morning lol
Old Jun 29, 2010 | 11:17 PM
killagt's Avatar
if you have a gf or wife with very small hand, USE EM . ask em put the socket on spark plug and you turn em. you dont know how many time I drop tool on tight spot that my big hand can get thru, i ask my gf, since her hand is very small
Old Jun 30, 2010 | 12:30 AM
94maro's Avatar
snap on makes a speical spark plug tool its like 30 bucks...its small just wraps around the spart plug and u can use a wrench or a socket on it depends on space..but going from underneath on a couple helps a lot!! gl man
Old Jun 30, 2010 | 01:01 AM
letsrun97z's Avatar
Yeah I grined down an extra socket then cut a slit in it
