torque specs? and head bolt sequence?
Old Jul 4, 2010 | 12:58 PM
Purple94Z28's Avatar
Default torque specs? and head bolt sequence?
Okay so i need to figure out a few things?
1. Oil pan torque specs? i think there is two because of the bigger bolts at the ends...?
2. Timing cover torque specs?
3. Stock Rocker stud torque specs w/ guide plates installed?
4. Head bolt sequence?
5. Also is there a sequence on the intake manifold?
I know there is a few more i need but that's all i can remember right now.
Thanks,
Nick
Old Jul 4, 2010 | 01:07 PM
RamAir95TA's Avatar
shbox.com has everything you're looking for.
Old Jul 4, 2010 | 01:28 PM
Spiers's Avatar
Oil pan corner bolt/nut: 15 ft/lbs
Oil pan side rail bolts: 106 in/lbs
Timing cover bolts: 106 in/lbs
Rocker arm stud: 50 ft/lbs
Head bolt sequence: http://shbox.com/ci/head_assy.jpg
Intake manifold sequence: http://shbox.com/ci/intake_sequence.jpg
