How long can it sit?
if your worried about corrosion build up in the cylinders you could always use a fogging spray. i use this on my boat and jetskis during winter storage.
Your Car can go a very long time 3yrs or more indoors. Outdoors is another thing.
Since I had to do this about 5 times in the last 10 yrs, and the car has about 270,000 miles on it, and is in unheated , no A/C, stowage shed att, here is what I do. Just a little prep time and some common sense.
This is the list I use.
Pre stowage
1. Wash & wax the car real good a few days prior to stowage. Put and leave wax on any chrome or chrome wheels.
2. Fill Fuel tank full up and adding fuel system cleaner and stabill to it.
3. Fill tires with nitrogen they dont seem to go as flat as when I didn't. I also spray with a dryrot preventive spray.
4. Just prior to stowage Drain the old oil and change filter. put in your fav brand I put in Shell Rotella Synth 5/40 or Mobil 1 15/50. I overfill at least 2 qts.
5. Check your anti freeze make sure it way beyond the coldest your car may see in your area.
6. I change Trans fluid as well, I put in fresh just prior to stowage.
7. I give the car a complete grease job, I use a good synthetic grease.
8. Spray disinfectant in the A/C ducts.
9. Pull out the plugs and spray in fogging oil, use liberally.
10. Disconnect and remove the battery. put on a solar or timed charger, having someone check on it each month.
11. Put a air freshner in the car and put a good breathable dust cover on it.
12. Put the car on 4 jack stands, on the lowest setting with tires able to spin 1/8" only, or so.
Post stowage
1. Spray disinfectant in the A/C ducts.
2. Connect and install the freshly charged battery.
3. Put a new air freshner in the car.
4. Check and fill tires as needed.
5. Pull out the plugs and spray in fogging oil, use liberally
6. Wash & wax the car real good, to remove stowage grime, old wax, and dust.
7. Remove car from Jack stands.
8. Check your anti freeze, and brake fluid. Make sure it still looks ok. Check for leaks, and all fluid levels.
9. Drain excess qt oil and pour in valve covers, change oil/filter, on a short interval like 1st few hundred miles.
10. Fill up tank and put in best octane rated fuel you can.
11. Drive the car for a few short trips then go on a couple long trips, run a fuel systems cleaner in the car at 1st few fillups.
12. Check for signs of pest, insect nests, spider webs, or mold in your car and get it removed if it was kept outdoors.
Hope This Helps.
Dub
When In Doubt Do Without
