horsepower question
Old Jan 18, 2004 | 02:27 AM
94355LT4's Avatar
Arrow horsepower question
hey ive got a 355 LT4 in my formula M6 and ive got the following mods:
bored .030" over ,ported intake manifold,comp cams lt1 306 cam,1.6rr,port and polished heads,sealed power pistons,tuning from pcmforless.com,mid length headers,y-pipe,cut-out,flowmaster 2-chamber,lt4 knock module,k&n intake,MAF, tbody bypass, air foil,crank and alternator pulleys,resonator delete, almost all the free mods there are.
i was just wondering if anyone has an idea of how much power i might be lookin at. i talked to a racing company near me and was told 360rwhp at the most yet im seeing guys here with a lot of the same stuff are getting over 400rwhp. so if anyone has an idea thanks.
Old Jan 18, 2004 | 02:35 AM
Vendetta's Avatar
Take her to your local shop and have her dyno'd for a few bucks, then you can find out for sure!!
Old Jan 18, 2004 | 08:21 PM
solid95z's Avatar
Depending on how well your heads flow, the port velocity you have in the heads and your compression is what's gonna determine most of that. If the heads are ported real good you could see about 400 (with a gooood tune). If they are stock then prolly about 360 or so. That's just an educated guess.
I agree with Super Mario, take it and get it dynoed and you will know for sure. That way you can see exactly what the car is doing and make adjustments from there to get more power.
Old Jan 19, 2004 | 01:50 AM
94355LT4's Avatar
the heads were put on the cnc machine at my machinists, i dont know what the specs are on them, all i know is they were bigger the intake ports matched my intake manifold and they were polished smooth as glass.
Old Jan 19, 2004 | 01:58 AM
Vendetta's Avatar
my guess would be anywhere between 370-390 rwhp depending on tune and the head job.
Old Jan 19, 2004 | 09:15 AM
solid95z's Avatar
What you can do is ask your machinest if he flow tested the heads. If he did then get the flow numbers and that will give you an idea of how the heads can potentially perform. If he did not then all you can do is dyno the car and see what it does.
Scott
Old Jan 21, 2004 | 08:20 PM
Gangly's Avatar
should put out more than 360. i have a 96 6-spd, ported heads and intake, 224/230 cam, midlengths, y-pipe, cutout(after the cat),etc, and put down 360 after both collector gaskets blew on the dyno and a plug wire melted on the header.
