stock block compression/ head ?
Old Jul 7, 2010 | 11:55 PM
SPRAYED Z's Avatar
Default stock block compression/ head ?
Whats the stock chamber volume on bone stock lt1 untouched heads, engine? Im wondering what it would be once I change heads and gaskets. thanks
Old Jul 8, 2010 | 12:02 AM
RamAir95TA's Avatar
Stock heads are 58cc from what I recall.
Gasket thickness does not determine head CC size. The only way to have the head CC measured is to have them CC'd.
Old Jul 8, 2010 | 12:03 AM
RamAir95TA's Avatar
Old Jul 8, 2010 | 12:05 AM
SPRAYED Z's Avatar
ok thanks and what about the pistons, what type of valve reliefs are they 5cc or what?
ALso do you know the deck height of a stock block and far in the hole the pistons are?
im trying to input numbers in to find out my compression and i want to make sure of them.
its a stock block with 57cc heads that were milled and a .026 gasket. Do you know what it might be?
Old Jul 8, 2010 | 12:08 AM
RamAir95TA's Avatar
Stock piston volume has -5cc reliefs. Piston depth on a stock block is around .015" to .020". I've seen some as deep as .030" though.
Old Jul 8, 2010 | 12:54 AM
SPRAYED Z's Avatar
well using a .026 gasket and deck height of .020 I get a 10.8 compression. That seem correct?
Old Jul 8, 2010 | 02:52 AM
suicidal racing's Avatar
i know with my .15 gasket an 58cc heads with stock deck im around 11.4-1 comp..
Old Jul 8, 2010 | 12:09 PM
SPRAYED Z's Avatar
SO I will be good thanks
Old Jul 8, 2010 | 01:21 PM
speed_demon24's Avatar
Stock heads are ~54cc FWIW not 58.
Old Jul 8, 2010 | 05:04 PM
^there 58cc every spec site online about lt1s and lt1 flow nums say 58cc and my 93-92 camaro book says 58cc in the lt1 section also if i remember right
Old Jul 8, 2010 | 06:51 PM
Purple Poncho's Avatar
I have always heard 54cc.
Old Jul 8, 2010 | 08:48 PM
wrd1972's Avatar
I say 54cc too.
Old Jul 8, 2010 | 09:21 PM
Spiers's Avatar
If I'm not mistaken, the LT1 heads are 58cc, and the LT4 heads are 54cc.
Old Jul 8, 2010 | 09:52 PM
Speedy's Avatar
Mine cc'd at 55. The numbers seem to vary everywhere you look. They are definitely not 58cc.
Old Jul 8, 2010 | 09:57 PM
Spiers's Avatar
What I stated above is what it reads in the book "How to Rebuild Small-Block Chevy LT1/LT4 Engines."
Old Jul 8, 2010 | 10:07 PM
robsquikz28's Avatar
I remember seeing them at 54cc and lt4 at 54.4cc But I asked Lloyd once about 2 years ago and he told me 58
Old Jul 9, 2010 | 08:52 PM
Speedy's Avatar
Look on page 14 of that book under specifications. LT1 54.4cc chambers and 170cc intake port volume. LT4 54.4cc chambers with 185cc intake port volume.
I have had a shop tell me I had 58cc heads. I had to show him the stats to change his mind. He insisted on cc'ing the heads, refused to believe the documentation. 56-55cc is what we got on 1993 LT1 heads. It seems to vary from head to head, possibly from year to year. I don't know where so many are getting 58cc. Possibly the #s changed from year to year? Does it possibly have to do with the valves?
I would like to know where the 58cc number is coming from.
Old Jul 9, 2010 | 09:02 PM
RamAir95TA's Avatar
Anyone want to put up and have their stock heads CC'd?
Old Jul 10, 2010 | 12:40 AM
SPRAYED Z's Avatar
I dont have stock heads or I would Im not sure what they are
Old Jul 10, 2010 | 06:44 AM
this pages says everyone is half right..lol
http://www.purplesagetradingpost.com...fo/heads1.html
this says lt1 are 58cc an lt4s are 58cc..lol
http://racingfeed.com/downloads/chevy_flow_data.pdf
