Need throttle cable.
Old Jul 9, 2010 | 07:36 PM
draggin97s10's Avatar
Default Need throttle cable.
Its a 97z. i need options on throttle cables. The dealer says the part is discontinued. Is there anywhere i can find one gm or aftermarket. Part numbers would be greatly appreciated.
thanks
Ryan Gash
Old Jul 9, 2010 | 07:47 PM
RamAir95TA's Avatar
Which cable do you need? Do you have TCS/cruise?
Old Jul 9, 2010 | 08:01 PM
LT1's Avatar
LT1
I have a extra throttle cable for a 95 Z28, if that's what you want give me a Private Message.
Old Jul 10, 2010 | 09:46 AM
no, cruise removed just throttle.
Old Jul 11, 2010 | 01:42 PM
smb72's Avatar
I just bought a new one off Ebay. Paid $44.00 shipped to my house. GM part # 12550676 (fits 94-96). It fits and works like the old one.
Old Jul 11, 2010 | 04:40 PM
Badazz 97 TA's Avatar
any 94-96 f-body cable will work as long as its non traction control.
Old Jul 12, 2010 | 01:41 AM
LT1John's Avatar
impala and camaro cables work just picked one up at the junkyard
Old Jul 12, 2010 | 02:23 PM
StealthFormula's Avatar
Did you by chance measure that one along with the '97 cable? Just curious because I have heard they may be slightly different lengths but I dunno the truth to it.
I see your over in Bethlehem, I'm down below Quakertown. I make my way up there for Musik Fest every year and hit up some of the local bars and the Sands casino once every couple months.
OP, the '97 cables are a pain to come by but I was able to buy two used ones off ebay, maybe take a look and see if any are on there. The '97's are actually called accelerator cables not throttle cables like the other years so keep that in mind when searching, part# is 12554852.
EDIT: Here you go, says it was removed from a '97 Z28, non TCS and is in good condition:
http://cgi.ebay.com/ebaymotors/NON-t...Q5fAccessories
Old Jul 12, 2010 | 08:22 PM
smb72's Avatar
both are the same length. only thing that was different between the two was the end that goes into the bracket on the manifold. It's somewhat different in design but still fits in the bracket. the bracket is the same for 93-97 lt1's.
yea i'm right up the road from musicfest.
Old Jul 12, 2010 | 09:53 PM
thanks for all the help guys. Im buy one from LT1. i also heard some where that one from an 93-02 s10 will work. weird. is that true?
Old Dec 30, 2017 | 11:42 AM
Tia Nicole's Avatar
Default Throttle cable
What year will work on a 95 Chevy caprice Lt1?
