3 dayz after installing my optispark it died!
Old 07-10-2010, 08:16 PM
xdanny510x's Avatar
Angry 3 dayz after installing my optispark it died!
just after i finished installing my optisprk from chandler motor sports. it completely lost spark! uffffffff now im really getting frustrated with this lt1... GRRRRRRR.. I think its time i either can this lt1 or start ordering my parts for my ls1...
Old 07-10-2010, 08:49 PM
JB_97ws6TA's Avatar
I was waiting for one of these threads to come up. If a deal sounds too good to be true it usually is. Sorry for your luck but I would not blame the LT1 for an 80 dollar opti failing.
Old 07-10-2010, 08:57 PM
old93camaro's Avatar
doesn't he have a warranty with them
Old 07-10-2010, 08:59 PM
xdanny510x's Avatar
it wasnt a 80 dollar opti. i bought the 175$ one with a lifetime warranty..
Old 07-10-2010, 09:28 PM
jay7199's Avatar
replace it.. And seal it with RTV.. search if you don't know what im talking about.
Old 07-10-2010, 10:54 PM
$750 L98's Avatar
^I'm with him
Failure = Opti not prepped before install. If it works it works, they don't just die after 3 days.
Old 07-10-2010, 11:45 PM
SPEEDYTRANSAM1996's Avatar
Hit up this Guy aka Thepartspro aka the main dealer to thepartsladi
800-579-7046 Tell them that you'd like to place another order for a opti for $260 , make sure you tell them $260 since someone pmmed me saying he payed $290 cause I bought one 2wks ago for $260 so see if it works ........
Old 07-11-2010, 12:15 AM
whytryz28's Avatar
Yes they cover 1 replacement, I got mine replaced under warranty before I got an AC Delco unit. Just email them and they will send one out.
Old 07-11-2010, 12:16 AM
whytryz28's Avatar
I caked the red RTV on my Delco unit along with red loc-tite on the rotor screws, hopefully this will last a while lol
Old 07-11-2010, 11:41 AM
Speedy's Avatar
How do you know it's the opti? Did you check the coil? There's people running Chandler optis with no problem. If it worked for three days then died you might want to take a closer look.
Old 07-11-2010, 12:00 PM
BTC
BTC's Avatar
Location: Lansing, MI via Bowling Green, KY, Dalton GA, Nashville, TN & Atlanta, GA
Agreed. I've been waiting as well.
So, their "lifetime" warranty only covers a single replacement? If so, that's pretty convenient, for the dealer.
Old 07-11-2010, 12:29 PM
Gojira94's Avatar
http://shbox.com/1/4th_gen_tech2.html#opti_test
Gotta troubleshoot... Ignition components work extra hard when one of them is failing. Not uncommon to lose a coil or module after replacement of wires, plugs or distributor. Next weakest link often fails.
Old 07-11-2010, 01:53 PM
xdanny510x's Avatar
i did that..
did that also
i checked the coil and as well i pulled a spark plug out and connected it to a wire and tried crankin it over to see of there was spark coming out and nothing.
Old 07-11-2010, 02:17 PM
RamAir95TA's Avatar
I'm sorry, but an aftermarket optispark shouldn't need to be taken apart and prepped before installation. That's retarded.
Old 07-11-2010, 03:48 PM
MattSapp95_T/A's Avatar
Did you check the ICM? usually an opti will run like crap when it goes out (at least in my experience)
Old 07-12-2010, 01:34 AM
LT1John's Avatar
noooo stop!!! i had this same problem. u might have the same opti i had when i was broke. there is a no name brand out there that comes with a life time warenty and is the biggest POS ever made in china. dont take it back because u WILL be changing it again in a few thousand miles. drop some coin on an accel. havent had a problem since.
Old 07-12-2010, 01:35 AM
LT1John's Avatar
it looks like a delco but it is not!!
Old 07-12-2010, 08:29 AM
BTC
BTC's Avatar
I'm not sure recommending an Accel replacement is the best advice.
Old 07-12-2010, 09:26 PM
Speedy's Avatar
Funny thing, I was talking to a mechanic today who used to work in a garage that did fleet service on police and taxi Chev Caprices in the 1990s. He said he replaced hundreds of optis. He said they only had GM units back then and some of them went 400,000 miles with cap and rotor changes!
Old 07-12-2010, 09:32 PM
killagt's Avatar
man those were the day huh ? good old day with lt1. Right part, right install, keep out of water = very long time , can you return it and order ac delco part ? it only a few day right ?
Quick Reply: 3 dayz after installing my optispark it died!
