My Battery Relocation Install...
Old Jul 13, 2010 | 10:30 PM
SoxXpupPeT's Avatar
Default My Battery Relocation Install...
Ive been wanting to do this for quite some time now. And when i modified my Radiators and dropped them down. It became a need for clearance purposes. I searched and found alot of helpful information on this site (as always) and just went for it!
First thing was to get a battery box.. In this case i decided to fabricate my own...
2, 3/8" bolts secure it in the spare tire well...
Battery mounted and all wired up Note: the 200 amp circuit breaker (bottom right) in line with the ground cable
Look no more battery!
Rough setup of how the wires are set. Subject to change.
All in all im very happy with the setup! it cleans up Alot of room in the engine bay, and it also puts a nice chunk of weight over the rear tires. I have not noticed any difference in first startup, or alternator drain. It starts up just fine like it always has. It also runs if anything, Smoother then what it did with the stock wiring..
For the wires i used #1 cable from the battery to the terminal in the engine bay. and from the engine bay splitter i used #4 wire to go to the alternator and the starter. I also used #4 wire for the ground in the rear...
I was going to run the main cable to the starter, but i wasnt sure how it was going to fit with my LT headers. I could always change it around next time if i notice any issues with power loss. The ground from the battery goes to the rear bumper support off the rail of the car. I took out the stock bolt and cleaned up the surfaces of everything the best i could. I hope that this will help others just like alot of others threads helped me!
Old Jul 14, 2010 | 09:05 AM
*02WS6TURK*'s Avatar
Looking good bro! I've thought about doing this myself.
Old Jul 14, 2010 | 09:36 AM
94Z28rag's Avatar
Pretty cool. I'm doing the same with my car, but have to used a sealed, vented box with a on/off on the rear bumper to be NHRA legal.
Old Jul 14, 2010 | 10:15 AM
brucer's Avatar
mount looks good.
you need an emergency cutoff switch or they wont let you run it down the track.
also isnt that style of battery suppose to be in a box thats vented outside the car?
i'm not sure, but, i dont think you have to mount a gel sealed battery in a vented box.
Old Jul 14, 2010 | 12:06 PM
riceburnerZ28's Avatar
All you need to do now is the wire mod!
Old Jul 14, 2010 | 01:31 PM
SoxXpupPeT's Avatar
Thanks bro!
Originally Posted by brucer
mount looks good.
Its a sealed battery so i dont think i need a battery box. I dont really plan on taking it down the track (anytime soon anyway) and if i do ill get an on/off switch just for safety.
All in due time my friend!
Old Jul 14, 2010 | 03:58 PM
chevy94c's Avatar
This is one of the next things i am going to do.
Old Jul 14, 2010 | 09:47 PM
SoxXpupPeT's Avatar
You will Not regret it..
Old Jul 14, 2010 | 09:51 PM
Z28Roxy's Avatar
Looks good. I love fabrication.
Old Jul 15, 2010 | 12:18 AM
Johnny-LT1-runner's Avatar
Rockstar
That extra space looks really nice. I'm really diggin the fabrication too.
Old Jul 15, 2010 | 08:12 AM
94Z28rag's Avatar
EDIT: You need a sealed box and a cutoff regardless of the battery to be NHRA/IHRA legal.
Nice work, btw
Old Jul 15, 2010 | 10:58 AM
AChotrod's Avatar
Looks real good!! Im also debating on if i should do this. I just dont want to cut a hole for the cut off switch.
Old Jul 15, 2010 | 12:47 PM
94Z28rag's Avatar
You don't have to cut a hole in the body for the switch.
Old Jul 15, 2010 | 10:50 PM
SoxXpupPeT's Avatar
Default Thanks!
Thanks for all the kind words guys! I really appreciate it. It wasnt that bad of a swap at all! and i highly suggest it to anybody looking for not only more room, but a much cleaner looking engine bay. I will look into getting a switch for whenever i do decide to take it to the track. Ill also figure out some sort of cover too so i dont have to hear everyone complain about it lol. Today i decided to change alittle more things under my hood. And come up with something good for that new room. Whatcha think ??
out with the old...
And in with the new... (canton 2 quart overflow tank)
It adds a certain badass touch to the whole engine bay i think.
Old Jul 16, 2010 | 07:14 AM
Z28Roxy's Avatar
out with the old...
You need to clean the shock towers, crash brace in front of the radiator, etc.
Old Jul 16, 2010 | 02:55 PM
deerslayinrednek's Avatar
so where would a kill switch have to be? My new chassis already had the battery cables ran to the rear so I decided to leave it there but I didn't know I needed a kill switch on a 13sec car
Old Jul 16, 2010 | 03:15 PM
brucer's Avatar
on an nhra track and probably ihra, if you have a battery relocation kit, battery needs to be in a sealed box, and a shutoff switch located at the rear, in plain sight and labeled.
dont have a rulebook so i dont know the exact wording..
Old Jul 16, 2010 | 11:43 PM
DCC!!'s Avatar
NICE!! where are your wire ran? inside or outside?
Old Jul 16, 2010 | 11:52 PM
SoxXpupPeT's Avatar
Thanks~ I ran the wire on the inside. Kept it along the rear wheel well and ran it across the floor just under the rug. I passed it through the stock hole in the firewall behind and under the PCM
