Sexy!!!
Its actually a HSW tunnel mount but I didnt like how it fit with the 15lb bottle and it just happened to look great and fit there.
Engine bay is done just needs a good cleaning, Fuel lines from stand alone to reg and solenoid are done, bottles are in, just need to mount the fuel cell to the trunk, secure the fuel pump and finish a bit of wiring.
N2o main line routing
Regulator and plate kit
fuel lines from stand alone run with the factory fuel lines then threw the wheel well into the front of the engine bay to the regulator. Ill get pics of the cell once I mount it.
Waiting for the blow down and bottle blanket to arrive.
Cluster **** of wires lol
Hopefully in a couple weeks. The fuel jets for the nano tune should be here anytime. Then I just need to get a day to myself and make it out to the track. This summer has been busy as hell, hence the reason this install is taking for ever.
Tony its a 3gal cell unversial from Jegs/summit 8x8x15h, and the pump is a inline walbro 255, hoses are all Earls perform-o-flex and a A1000 regulator.
Wiring is done, fuel system is done, doing the plugs right now. Only things left are the blow down, & jetting(waiting for them to get here) and clean it all up.
cleanest engine bay on ls1tech for a street driven car imo
