some advice please!
Old Jul 14, 2010 | 12:26 PM
z28camaro1996's Avatar
Angry some advice please!
ok my car will start and run just fine. and ill let it run for 5 min and ill get in it and ill start to back up and it will die,then it really hard to start and you can tell its getting fire, when it turns over it will try to start but instead it will diesel and clatter. when it finally does start it will bog when you gas it or its acts like it dont want gas, also while that it will back fire out the tail pipe every now and then.ive changed the opti,icm,cps, and coil. any suggestions what it could be?
Old Jul 14, 2010 | 12:43 PM
killagt's Avatar
does it crank first time you put the key in ?
Old Jul 14, 2010 | 01:29 PM
Some times it does then some times it dont.
Old Jul 14, 2010 | 01:42 PM
killagt's Avatar
have you check your fuel pressure by hook up a gauge on the fuel rail ? im affaird its your fuel pump, but check the pressure first, make sure it have no leak some where. Like injector leak or something. Keep us update how it go.
Old Jul 14, 2010 | 02:27 PM
fuel pressure at idle is from 41 to 43 pounds. and it moves up and down with reving
Old Jul 14, 2010 | 03:25 PM
killagt's Avatar
if fuel pressure good and no leak. Then move to ignition. is this happent before you change all that ignition ? or it happent before you change those ?
Old Jul 14, 2010 | 03:57 PM
thats why i changed all that stuff exept crank position sensor its about a year old or so. i forgot to add that its not throwing any codes.
Old Jul 15, 2010 | 12:49 PM
could my hypertech programming went bad?
Old Jul 16, 2010 | 05:10 PM
i noticed yesterday it does it after it warms up.
