Pics of clearenced and welded timing cover?
I am going to install the timing cover and need to see were people have clearenced (however you spell it) there timing cover to accept a double roller timing chain. I will also be installing an electric water pump, and would like to see what people have used to plug the top hole where water pump drive was....
I didn't clearance my timing cover though since I didn't use a double roller.
As far as plugging the hole is concerned, I used JB Weld and a quarter. It's more than enough.
yeah, on the timing cover itself I used a quarter and jb weld, works perfectly. used a quarter from the year I was born probably should have used one from when the car was made
