quick question about pcm fuse
Old Jul 19, 2010 | 05:20 PM
Adam1203's Avatar
Default quick question about pcm fuse
the 95 lt1 camaro has no pcm fuse?
also the right side next to the coolant reservoir there is a black box with a vacuum line running to it. what is that?
Old Jul 19, 2010 | 05:30 PM
RamAir95TA's Avatar
The PCM fuse is labeled "PCM BAT" in the underhood fuse compartment.
The tank with the vacuum line is a vacuum reserve canister for the HVAC system.
Old Jul 19, 2010 | 05:34 PM
Adam1203's Avatar
sorry i just want to clarify then its not the same as the 3.4 which has its own fues that says pcm? sorry i just dont have the layout of the box suck in my head all i saw when i put the new harness in and looked at it. it said pcm and there was no fuse. so i ran over to my buddies 3.4 and it had a fuse. but i know it just said pcm no pcm bat. i saw a relay that said pcm bat i think though.
