Another Bad Day At The Track! Help Please!!!
Old Jul 23, 2010 | 10:25 PM
pboxfun's Avatar
Exclamation Another Bad Day At The Track! Help Please!!!
Well I finally went back to the track thinking my problems were solved. My car was shifting hard and quick, I just put a new stall in, and there was no more high rpm backfiring. But I guess there is still a problem. All my mods are in my signature.
This was my best slip of the night
R/T .175
60' 2.028
330 5.912
1/8 9.140
MPH 76.08
1000 11.930
1/4 14.286
MPH 95.82
The car felt like it had no *****! It would launch hard but take forever to speed up! I felt like it was just sitting still. Anyone have any idea what could cause this?? Could it be a fuel or compression problem? IDK what to do now. Any help would be great!
Thanks
Old Jul 23, 2010 | 10:53 PM
Badazz 97 TA's Avatar
ha! Thats slower then stock.
fuel would be a good place to start.
Old Jul 23, 2010 | 11:02 PM
BackinBlackZ's Avatar
I thought mine was slow...but it is stock!! Anyways, with your mods. cant help to think timing is being pulled. Also, you running the stock MAF? Curious what your MAF is reading?
Old Jul 23, 2010 | 11:03 PM
WhitePhoenix99's Avatar
Has the car been tuned?
Old Jul 23, 2010 | 11:06 PM
pboxfun's Avatar
How can you tell if you have a problem with fuel? But yes the stock MAF is still on there. Why do you think it might be the MAF? The car has been tuned by MadZ28
I know this is killing me right now because i was running 14.1 with just exhaust and intake! lol
Old Jul 23, 2010 | 11:16 PM
There is definately a problem. Your trap speed is around 10mph off what it should be. I would get the tune checked out asap.
Pull a few spark plugs and see what they look like.
Old Jul 23, 2010 | 11:22 PM
pboxfun's Avatar
Yea I'm thinking of just buying tuning software and trying to figure out whats wrong myself. But I just changed the sparkplugs to NGK tr55s last week because i was having a high rpm miss. After i changed them the miss went away.
Any other ideas or solutions??
Old Jul 23, 2010 | 11:34 PM
How did the plugs look when you changed them?
Old Jul 24, 2010 | 02:33 AM
lethal bird's Avatar
there is something wrong with the tune. i ran with just exhaust, cai 1/8 8.77 and 81 mph
Old Jul 24, 2010 | 04:10 AM
97LT1's Avatar
I would be looking for knock retard.
Have you run any datalogging to see whats going on in the computer?
Old Jul 24, 2010 | 04:53 AM
pboxfun's Avatar
The plugs didn't look too terribly bad when I took them out. They were just worn out old platinum plugs. What would I need to datalog my car?
Old Jul 24, 2010 | 05:46 AM
LT1's Avatar
LT1
Have you tried running LT4 KM?
What RPM was your trans shifting at?
What's your rev limit set at?
Old Jul 24, 2010 | 10:42 AM
97LT1's Avatar
I used to us an LT1 scanmaster to keep an eye on current conditions while driving. It can sense when you pull full throttle, and then display max knock retard at end of run. It will help you put your finger on it if its there.
Old Jul 24, 2010 | 11:54 AM
Like I said, timing is being pulled from KR. Also, I believe you might be outflowing your stock MAF. Where is your MAF reading at? Did you mod. it?
Old Jul 24, 2010 | 11:56 AM
Attack rate can be modified to help recover some power lost. Just not good if it's actual KR.
Old Jul 24, 2010 | 11:59 AM
This guy has it right. Scanning takes the guess work right out of the equation!!!
Old Jul 24, 2010 | 03:16 PM
pboxfun's Avatar
No, ive never used an lt4 knock module. The car is set to shift at 6100 rpm and the rev limiter is at 6800. The MAF sensor is just descended. Do you really think I'm out flowing the stock MAF with just a cam?? There is no headwork done.
Old Jul 24, 2010 | 06:39 PM
....you might.......wont know till you scan!! Get the scanning!!!
Old Jul 24, 2010 | 06:42 PM
Stock (exception of CAI) my LT1 (auto) ran a 9.1@79.1 in the eighth. I made 2 runs with slips. That was my best. Def. something holding your power back!
Old Jul 24, 2010 | 08:36 PM
speed_demon24's Avatar
Throw it on the dyno after a basic tuneup.
