LS1 on LT1
#41
buy an lq9 out of a denali or escalade from 03-06 and there is all of your sensors, trade the truck pan for a camaro pan and you can get a ls1 k-member dirt cheap, and a computer and harness in the range of $500 dollars
#42
Stick with 2004-back..they have a 24X Reloctor.
Ya there are a few things missing..lol
You left a couple things out bro..lol
The L92 Heads suck for boost..they lift.
And a few other things called motor mounts or a new k member...transmission, wiring harness...sure its a great bang for the buck if you know/or have time to sort out the project. People have done it such as the merv...its not that cheap though. The block doesn't include sensors...oil pan, reluctor wheel, crank sensor....
Unless you have already started on your build you might want to look into this potent / great bang for the buck combo.
LQ9 Iron block $750 (GM Performance New)
GM Performance L92 heads $8-900ish (assembled!)
L76 G8/Holden intake $199
Cable TB with cable bracket for L76 from a sponsor $???
Forged 402 Rotating Assembly (balanced) $1900
I believe this combo is good for upwards of 500hp with the right cam. I have heard the unmilled 70cc heads are great for boosting as well. Good luck!
#43
Hey:
87TType: Not LTX but maybe this is where this keeps coming up from:
Dub
87TType:
I am fairly new to the LT1 and LS1s im currently building a LT1 and have a few questions. From what I have been told you can put LS1 heads and intake on a LT1.
Main reason I ask is because i would like to know if it would be smarter using LS style on an LT. I plan on doing a 383 stroker turbo'd on ethanol pump gas, and would like to see horsepower in the 500 to 600 range at around 6000 rpms. This will be my first Horsepower engine build so as much information as I can get will help me reach my goal.
I also have 4 years of Auto tech training just nothing on the performance side of things, and currently a Tech as well.
Dub
#44
Regardless of which way he powers it (LSX/LTX) he is gonna need sensors etc......and yes there are details like the 24x reluctor/ 2x cam (If he even uses an LS1 pcm) Even then Ligenfelter makes a conversion box to run any reluctor on that pcm.
Maybe I shouldnt assume that he already knows he is going to need motor mounts?
To the o.p. My point wasn't to lay out every sensor,bracket and bolt you would need to put an lsx engine( or LT1 for that matter) into your car (Thats Mervs job
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
How about 550hp from a carburated L92 setup for under $4900?
http://www.carcraft.com/techarticles...ads/index.html
Good comparison here
http://www.gmhightechperformance.com...ads/index.html
