connection c105
Old Jul 25, 2010 | 03:58 PM
Adam1203's Avatar
Default connection c105
what is this connection and what does it do? i bought a new body wiring harness from a forum member and it doesn't have a connection for c105 is this normal or did this guys screw me
Old Jul 25, 2010 | 04:07 PM
shbox's Avatar
Not enough info here, but only 95-97 harnesses have a C105. You probably got a 94 harnesses if you were expecting a C105 and don't have one.
http://shbox.com/1/harness_connector_faces.htm
Old Jul 25, 2010 | 04:09 PM
Adam1203's Avatar
im sorry i dont know enough about wiring. the body is a 95 the motor wiring harness is a 1995. the body wiring harness i was told was a 1995.
it looks like the plug is mostly for traction control.
Do all 95 body harnesses have this plug or only ones that have traction control.
Old Jul 25, 2010 | 06:59 PM
Adam1203's Avatar
So whats the deal here? do i need this plug or is it really just for traction control
Old Jul 25, 2010 | 07:10 PM
shbox's Avatar
Obviously not, if your read all the wire descriptions. If C105 is not there, it is not a 95 harness. You would have to compare differences of the other connectors in the harness to patch it together to make it work. Not the ideal thing to have to do.
No, it's not a traction control thing only. All 95-97s have C105, like I said.
Old Jul 25, 2010 | 07:44 PM
Adam1203's Avatar
thanks
Old Jul 25, 2010 | 07:57 PM
the_merv's Avatar
Get a Pin Diagram and match the Harness to see exactly what it is if you need to.
Old Jul 25, 2010 | 08:22 PM
Adam1203's Avatar
the wires aren't even in the harness. i contacted the person i bought it from on here im not very happy.
Edit: well i just found out this out of 94 so i have to pull it back out.
im going to guess the 95 is not the same at the 96-97 forward body harness
Old Jul 25, 2010 | 10:18 PM
shbox's Avatar
You can see all the differences in the link I posted. 96-97 is not identical, but closer than a 94.
