Some pics of my intake set up
Old Jul 28, 2010 | 03:59 PM
Transamthunder's Avatar
Originally Posted by *02WS6TURK*
Mines very easy going and loves some muscle...but if I started building in the house I would have to lube up the #8 cylinder and stroke away.
Haha, that is totally funny. I got a 2 car garage and it still to full of parts. Just goes to prove, even when you have the room for something, you always have ways of filling it up.
Old Jul 28, 2010 | 04:09 PM
the_merv's Avatar
Veteran: Air Force
You guys that are building engines in the house must be living the bachelor life
Ya something like that..
I have a 3 bedroom house..got to put something in them..
Originally Posted by Matts94Z28
kitchen build here too
Damn rite..don't have to go far for the beer..
Old Jul 28, 2010 | 05:14 PM
suicidal racing's Avatar
^lol my parts room is also where i keep my home made whisky..i dont touch it though if im building stuff.
Old Jul 28, 2010 | 05:42 PM
Originally Posted by Puck
Bit optimistic, but the combo should fly nonetheless.
Lookin forward to when its done .
i think it will be there..this aint a daily driver motor.its a motor only spinning a alt off the front and will be running on c16 unless the motor dont like that.
heres the whole motor specs
stock lt1 long block almost..lol
b&b 7qt race oil pan (ill run 5 in it)
melling oil pump
11.4-1 compression (.015 shim gasket)
750cfm carb(just came off a 10.5x bracket car)
holley strip dom (300-25) 4500-7600 rpm range
242/248,.567/.585 ,112 lobe doug herbert cam
1.5 roller rockers
ls7 lifters
1 3/4 headers 3" collectors
6"x3" mufflers ( there more show then anything.)
no acc's but alt
c16 race gas
Car specs will be
2900#s with me in it
275 hoosier dr's
race built 350 with mvb
4500 stall
3.89 gears
full race suspension
Old Jul 28, 2010 | 06:41 PM
Z8'S's Avatar
Doesn't need c-16.JMHO
Old Jul 28, 2010 | 06:49 PM
i dont think it will either on motor an in n/a trim..but on the 200 shot ill be using it..ill try a couple fuels out.
You never know till you test..if i had a dyno and more money into this i would dyno and do test hits for a day..
Old Jul 28, 2010 | 07:00 PM
the_merv's Avatar
Veteran: Air Force
I'm still trying to figure out why you would only run 5qrts in that pan..
Old Jul 28, 2010 | 07:30 PM
mdacton's Avatar
dont get your hopes up cause your building a 12 second rocket pal.
Old Jul 28, 2010 | 07:40 PM
merv less crank windage..its an old grumpy jenkins trick that is still used by super stock and stock eliminator guys..ive heard of as low as 2qts of oil in a pan.
she will do low 11s high 10s on motor at that weight..9s on the juice..like i said this motor is just junk slapt together..the turbo motor will be a diff animal..car will then run 4.90s or so in the 1/8th.
Old Jul 28, 2010 | 07:48 PM
lt1badbird's Avatar
sounds like alot of bench racing to me......
Old Jul 28, 2010 | 08:15 PM
Z8'S's Avatar
My thoughts exactly
Old Jul 28, 2010 | 08:23 PM
  #32
Black94Z28's Avatar
Setup looks sexy! Starting to motivate me to start aquiring parts! How are you going about getting the intake mounted to the heads? Drilling the heads or intake?
Old Jul 28, 2010 | 08:25 PM
  #33
lol it all is till your on the track..and then once your off it and back at home on your pc its bench racing still..
if you dont think a 470hp engine will push a 2900# car with driver in the low 11s an 10s then you need to open your eyes.
dont forget the lt1 bolt on record is 11.48 an that was stock long block with just rockers at 3100#s...tom dynoed around 310rwhp with that deal.
**** look at gizmo's car not as much hp as ill make and runs 11.0s i think..also is heavier.
Old Jul 28, 2010 | 08:32 PM
  #34
Black94Z28's Avatar
Get the sucker to hook and you should be there! Im trying pretty much the same thing on my 94. Figure weight reduction+cam+nos+stall+gears+drag radials should get me in the 10s
  #35
Z8'S's Avatar
How are you going to make 200+ hp with a carb intake and a cam on a STOCK LT1 with 1 point more compression?I know that Gizmo's car wasn't built with junk parts and without alot of testing .
Old Jul 28, 2010 | 08:39 PM
  #36
Black94Z28's Avatar
I believe he's spraying the car too, i could be wrong though?
Old Jul 28, 2010 | 08:46 PM
  #37
Z8'S's Avatar
Claiming 470 NA
Old Jul 28, 2010 | 08:55 PM
  #38
lt1 is rated at 275hp from factory..we all know they make more then that though seeing you have stock lt1 a4 cars putting down 220-235 rwhp an 275 rwhp with just headers (dyno page up top shows this) theres also camed,full bolt on m6's in there laying 350-380hp.
So with that being said ill have
better oil pan vs a stock one( i know you know how much a oil pan means on a motor)
1 pt more compression
bigger cam then stock,but not to much..it is lil bigger then i would run if i was just n/a
true roller rockers.
open headers pretty much the schielfield 3x6 muffs aint much trust me.
less restrictive intake with better port lay out
Race gas
No accessories but the alt an even then i may just go to a 16 volt deal.
as for gizmo's car im talking about the build he did with the kids went them numbers..7.05 and 11.0s..i can link that thread in here if you want..there using stock cam,oil restricters in the valley to stop cam windage,stock pan,ls7 lifters,roller rockers an are running a f.a.s.t deal with no accessories also..other then that i believe there around 10.8-1 comp..there using a impala gasket.an i think the car is 3100#s..i cant remember if there on race gas or 93 though..more then likely race.
Old Jul 28, 2010 | 08:59 PM
  #39
Z8'S's Avatar
Pretty Optimistic.....Good luck.
Old Jul 28, 2010 | 09:01 PM
  #40
lt1badbird's Avatar
cant wait for dyno results. someone make this **** a sticky so every lt1 owner is out runing 10's. a singe plane, roller rockers, mild hyd roller cam, race gas, and no accesories and yout stock headed lt1 is on its way to 470+ rwhp
