I need help please
Old Jul 28, 2010 | 11:47 PM
mrchyzy16's Avatar
Well if it still stumbles, then its probably not the o2 sensor cause when you go full throttle, it stops taking readings. It could be the optispark but i would check the tps first. Seems like the optispark is used as a excuse way to much.
Old Jul 29, 2010 | 06:41 AM
1994 interceptor's Avatar
Yeah I talked to a mechanic and he said that if it was the opti then the car would not start at all so I'll try the tps sensor
Old Jul 29, 2010 | 07:21 AM
moehorsepower's Avatar
This is not entirely true, you can have a bad opti and the car will still run, (like crap) but run, at times some will run fine cold then once warmed up, start missing, some only at WOT, there is a lot of different scenarios with a bad opti.
Old Jul 29, 2010 | 09:23 AM
1997 Z71's Avatar
So the scanner is what I would have to use it won't work if I jump it
1994 & up you MUST use an OBD1 scanner.
Old Jul 29, 2010 | 12:09 PM
I used an obd1 scanner and it didn't read any codes it said n stored codes what else should I do
Old Jul 29, 2010 | 12:45 PM
Formula WS6's Avatar
was the SES light on when you scanned it?
Old Jul 29, 2010 | 03:17 PM
Yeah I couldn't read any codes thow none not stored came up
Old Jul 29, 2010 | 08:49 PM
So I replaced the tps sensor and it still acted up and it popped real loud when I gave it full throttle what does that meen????
Old Jul 30, 2010 | 10:39 AM
SS RRR's Avatar
Village Troll
Have you changed plugs? If so, the plug wires could be crossed. If not then most likely your opti rotor is coming loose.
Old Jul 30, 2010 | 10:55 AM
mrchyzy16's Avatar
yep. if its popping through the exhaust then either the wires are bad or crossed like he said. I would check the wires first before you do anything.
Old Jul 30, 2010 | 12:11 PM
I have changed the plugs and wires bout 2 weeks ago to some ngk tr55 and some msd wires there not crossed I double checked them and they ok
Old Jul 30, 2010 | 12:14 PM
  #32
IT was doing this before I changed the plugs and wires
Old Jul 30, 2010 | 08:20 PM
  #33
Would I have to take off the water pump to relace the rotor???
Old Jul 31, 2010 | 01:07 PM
  #34
Gojira94's Avatar
1badzee's writeup on Opti replacement is a good one if you want a visual on what replacing it entails
http://www.lt1engine.com/tech/93-97-...emove-replace/
