lpp header install issues? need advice.
Dub
id anyone have to bend it to get around the header?
Dub
I moved the steering column over as much as poss. Then I notice the shaft was still a problem . So I busted out with the grinder and smoothed stuff out .
In the red I smoothed out the edges as much as needed , just keep putting on and your see how much more to go.
In the blue I grinned it till it was smooth with the bearing " The PINK CIRCLE "
Uploaded with ImageShack.us
You will have to do this to all -4- sides
The bolt will probably end up sticking out also like mine but you can either cut it flat with the shaft or get a shorter bolt.
