Fitment of Hedman 65386 Stepped Headers
I was thinking of getting a pair of these but I've heard there are fitment issues with stock steering linkage. They are the 1 3/4 to 1 7/8 stepped version. Can anyone confirm this and if so how and where is there a problem? Not sure if I manual rack is the only way for it to work or not.
I'm hoping for Outlaw, Tony, FastFatboy, and anyone else who runs Hedmans to chime in with some info.
Also what oil pans are you guys running or on the other hand which have you tried to run? Hedmans size says "stock width oil pan" It also says no to A/C and power-steering. [I have neither]
Thanks.
-Dustin-
Thanks.
-Dustin-
My stepped set, cleared the factory pan just fine. I had to cut my heater box in half(basically), for the passenger side to clear. The drivers' side, 1# primary, I had to cut it off, and fab up a new one. There was NO way for it to work, unless you caved it in. Ground clearance is alright as well.
My HVAC and PS are gone anyways, but I don't have the manual rack. I have a Milodon 30909 pan...sounds like we may have to get a bit creative, won't be the first time...
Thanks guys for the info, anyone else?
-Dustin-
-Dustin-
