help
Okay I posted up like a week ago saying i had fuel issues but turns out guy says its my coil... will it make the car break up real bad and at idle sound like im camming ? I definitely thought it was a fuel issue ... but if I should replace coil what's good brands to go with I'm basically all stock with lt ory slp exhaust and intake should I just get replacement at parts store or upgrade ?
something like this ? http://www.summitracing.com/parts/MSD-84811/ or this ?http://www.summitracing.com/parts/MSD-83811/ would either or work ? and also whats the big difference between to the two to make the cost so much more and what will i gain from buying the better one?
yeah i do have a 95 and i gotta ask the guy i forget what he said i am on vacation and he called when i was on the way to the beach haha so i was half listening i believe he said coil but if i replace the coil should i just buy the other stuff cap rotor and distrubtor at the same time ? or just let it be
The coil supplies the spark - the distributor, well, distributes the spark to the cylinders (and provides the PCM with the low and high resolution pulses it needs to fire the injectors).
They are two completely different components.
MSD is either hit or miss. You will find that more people have had luck with the AC Delco than the MSD. Some people swear by them, but it's just not worth the risk.
JMHO, of course.
JMHO, of course.
