head gaskets/milling heads
from what ive read around .025?
Have you had your current combustion chambers CC'd?
from the thread searches Ive done the thinest gaskets are the impy ones. Is there anything thinner than that?
I am not sure on the deck height or anything else really(i would say they are stock). The heads and intake I have were done by one of the guys who has 5 cars back in 96.
I know he gasket matched them and did a valvejob. since they are opened up a bit I think they would drop the compression and than I will be on a 40 over bore dropping the compression further.
if someone else built the engine, they may have decked the block to start with, you need to make sure either way.. then you go for the quench measurement... think it would be more important than compression alone..
anyways,
to figure the compression correctly you need to know how far the pistons are in the hole to start with.. then you go to the compression calculator..
