Motor or driveline problem???
The car is a 96 z28, m6, 43k mi...
mods:
-golen forged 383 shortblock, purchased in oct. 03. Motor has roughly 10k
mi.
-Ported stock heads by AL who works/worked for lingenfelter. valve job, full port, 2.02 1.6 manley valves
-ported lt1 intake, 58 mm tb
-comp xe 230 236 custom grind
-1.7 comp high tech stainless rr's
-patriot extreme spring kit
-comp chromeoly rods
-42lb injectors
-pacesetter lt headers w/ ory
- fm catback exhaust with electric cutout
-rpm built 6spd w/ spec 3 clutch
-moser 9" w/ 3.90 gears
-the normal suspension mods
anyways on to the problem...
Last saturday My bro Launched the car on the street at 4500rpm. Shortly after he herd a noise and saw the oil pressure drop to like 40psi(normally runs up around 60). So he pulled over and got out to hear this "knocking" sound coming from the back of the engine. Didnt sound good so he shut it off and towed it over to our dads shop. Today we push the car into the shop, pull the plugs and everything looks fine. So we proceeded to crank the car over with no plugs and the engine sounded smooth w/ no issues. Every cylinder had lots of air pushing out, so it seems all holes are alive... oil pressure constant 50psi aswell. Could this be a driveline issue with the clutch or flywheel? At this point were not convinced the motor is trashed yet... some opinions on this issue would be greatly appreciated!! Oh and it fires right up, but runs rough... Im assuming the knock sensor is being triggered and its pulling timing lol. Other than that the engine seems to run ok minus the horrible knock sound coming from the back of the engine. its only been ran for a couple of seconds since the issue occured... didnt want to cause anymore more damage.
