Super slow lt1 14.75 e.t
Old Aug 11, 2010 | 08:55 PM
Brando5641's Avatar
Default Super slow lt1 14.75 e.t
I have a 97 t/a CAI, new MAF,PLUGS,MAP,Fuel Filter, the car has no codes but it is a turd. The best time i got out of the car was a 14.75 out of 5 runs. Is this normal for a A4 car?? i was thinking it would get atleast a high 13.
Old Aug 11, 2010 | 08:59 PM
IronOutlaw's Avatar
Give us the whole time slip.
Old Aug 11, 2010 | 09:05 PM
Jcl_96TA's Avatar
It should run around 14.00 @ 99-100mph stock so something isn't quite right there. I would start with a tune up of the ignition system. The complete time slip will tell the story a little better like stated earlier.
Old Aug 11, 2010 | 09:16 PM
355z28's Avatar
What was the DA? Where are you located, what track?
Old Aug 11, 2010 | 09:18 PM
Meen95z's Avatar
Depends, if its a A4 with 2.73 gears, its never gonna see a 14.0-14.3 pass stock, maybe a 14.5-14.7.. If you have the 3.23 gears maybe see a 14.1-14.3 stock. I seen a few stockers go 14.1-14.3 area, but not too many and thats with 3.23 gears. Just from my experience, mine with cold and exhaust went a 14.0 consistently with stock 3.23 gears.
Old Aug 11, 2010 | 09:19 PM
trilkb's Avatar
thank the jesus's someone is slower then me!
j/k dude, Sucks your times are like that, i know how it feels!!
like the rest of the people said. give us a 60' time, and elevation. If you need to figure out DA (density altitude), Drag times has a calculator with almost every track out there.
Old Aug 11, 2010 | 11:04 PM
Badazz 97 TA's Avatar
honestly, its a little slow but Ive seen 14.5's out of a stock '96 Trans Am so its not that much slower.
Old Aug 11, 2010 | 11:45 PM
Bowtie Boy's Avatar
Originally Posted by Meen95z
Depends, if its a A4 with 2.73 gears, its never gonna see a 14.0-14.3 pass stock, maybe a 14.5-14.7...
right...
Do yourself a favor and dont listen to this guy. If you are running anything over 14.2 bone stock, either you need to learn how to drive, stop drag racing up with airplanes or there is something really wrong with your car. 14.5 or 14.7 in a stock TPI maybe.
Old Aug 11, 2010 | 11:47 PM
pyro719's Avatar
Altitude will play a huge role in power and track times. Stock ls1 cars run low 15's up here in the clouds
Old Aug 11, 2010 | 11:59 PM
l 95 Trans Am l's Avatar
Jeez, my 88 IROC ran 14.6 with a bad torque converter. Sounds like somethings off. Could be the stock gears as well. Make sure all connections are in line, how long have you had the car?
Old Aug 12, 2010 | 12:51 AM
dubga's Avatar
My pig-heavy vert A4 2.73 ran a best of 13.99 with a full tank of gas (less 50 miles) with a cai and catback. It runs 14.1 consistently in the south ga summer heat and humidity.
Old Aug 12, 2010 | 05:20 AM
96lt1m6's Avatar
DA,barometric pressure,humidity all play a huge factor in your ET, i really hate these threads cause you always get someone that runs 12s at sea-level and the same mods on another car runs 13s and it turns into "your car is messed up,who tuned it,you cant drive etc.....
Find out your tracks elevation,the DA at the time you ran and you will see the difference!
OP depending on your location these times are normal,dont get discouraged by previous statements.
Old Aug 12, 2010 | 05:55 AM
dlk1950's Avatar
Thats what my 97z A4 2.73s ran when it was bone stock. In the 1/4 it did not shift to 3rd till I was thru the traps,so don't be discouraged..Time to look into some mods.
Old Aug 12, 2010 | 06:06 AM
joelster's Avatar
DING, DING, DING!!!!!!!!!!!!!!!!!!!!!!!
Everyone is so quick to point out what "could" be wrong with his car. The OP is from Muscogee, Oklahoma which is 611 feet above sea level and it's been in the mid 90's to near 100 for the past few weeks.
I plugged in a scenario based on your elevation, 90 degree temp with 80% humidity, and I gave you a mph of 96 because you didn't post what it was. I corrected it to sea level at 60 degrees with 60 percent humidity and it gave you a 14.25 at 99.36
Old Aug 12, 2010 | 07:54 AM
Brando5641's Avatar
They wern't giving out time slips and my gf didnt look at the 60 time. I dont think its a 2.73 gear. 1st gear 40ish 2nd 75-80 3rd 125ish. I would guess 3.23. This was in tulsa ok on a 90 degree night and the car wasnt spinning at all. I also let the car sit and cool off to about 140 between each pass. I was very diapointed at how slow it was. I had a edelbrock headed small block that had a FUBAR holly and ran a 13.90 on 2.73's. I got a vid of the track night i will get it up on youtube and post a link.
14.75 @ 98 I think.
Old Aug 12, 2010 | 08:20 AM
Brando5641's Avatar
http://www.youtube.com/watch?v=jhNGyWPDjYI
The video is worthless b/c it doesnt show times.....
Old Aug 12, 2010 | 08:23 AM
95mysticta's Avatar
Times will differ but definetly a A4 with a 2.73 is going to be a turd. The DA and 60' will tell us what we need to know weather its the car, driver, or altitude killing your time. First time to the track this year i ran a best of 14.7 on street tires (M6, intake, catback, and 4.10s) with zero traction my 60's were 2.2s to 2.4s and trapping at 93-97. Just couldnt get any traction till 4th gear and well the race was over.
Old Aug 12, 2010 | 08:31 AM
chas010's Avatar
His times look right on to me. The mph would indicate if there was a hp issue but right around a hundred is good. My car started out as an a4 2.73 running mid 14s at 99.
Old Aug 12, 2010 | 09:25 AM
yeah those are 2.73s. my 3.23's shift at 33mph, 71, then like 110ish
Old Aug 12, 2010 | 10:23 AM
Smoke Em's Avatar
it looks like it falls on its face before the 60 ft and picks back up. the et seems kinda low but the mph seems about right for stock
