should i rebuild the engine?
Old Aug 12, 2010 | 03:58 PM
ryanosborne's Avatar
Default should i rebuild the engine?
ok so i original plan is to get a rebuild kit for my lt1 and a complete cam kit from ai. but i was told these engines are good for up to 300,000 kms . it for 120, 000 kms. what do you guys think? should i go ahead and get a rebuild kit while i get the cam kit and transmission rebuild kit and im also gettin headers
Old Aug 12, 2010 | 04:07 PM
94redz28's Avatar
I would check the front cam bearing and see if its wore out if you have the timing cover off.
Old Aug 12, 2010 | 04:09 PM
RamAir95TA's Avatar
What makes you think it needs to be rebuilt anyway?
Old Aug 12, 2010 | 10:02 PM
because a few people owned it before i did and i know the engine has been over heated badly a few times because they didnt know there was a manual switch to turn on the rad fan and i figured if i was getting a cam kit and a rebuild kit for the transmission and a new timing set and opti and headers i may as well get the engine done to but what do you guys think? i know the opti is bad because someone got it wet before and the car sputters and works terrible for the first few minutes you drive it and it hesitates sometimes but once you drive it for a few minutes it works great but i want it to work better and have more power
Old Aug 12, 2010 | 10:33 PM
RamAir95TA's Avatar
IMO, if it has good oil pressure and good compression, there's no real reason to spend the money, unless it's something you would feel is worthwhile doing. How many miles are on the short block?
Old Aug 12, 2010 | 11:10 PM
120,000 kilometers. oil pressure is good. how much of a difference will it have if i dont re do the engine but get the cam kit from ai and replace the timing set and opti and get headers
Old Aug 12, 2010 | 11:32 PM
slomarao's Avatar
when you do something like a cam with that many miles you run the risk of rebuilding the motor. The extra rev's and the stock bearings dont mix.
Old Aug 12, 2010 | 11:36 PM
so i should rebuild with it all?
Old Aug 12, 2010 | 11:39 PM
RamAir95TA's Avatar
Old Aug 12, 2010 | 11:54 PM
makes perfect sense to me, i dont really want to spend the money if i dont need to.
Old Aug 13, 2010 | 03:34 PM
so what should my compression be at and whats the best procedure to check it?
Old Aug 13, 2010 | 09:30 PM
RamAir95TA's Avatar
You need to do a compression test with a compression test gauge. Your readings should be within 10% of eachother with no cylinder significantly lower than the rest.
Old Aug 13, 2010 | 09:58 PM
i know that but do i remove all the plugs put the guage in one hole and turn the key while there are no plugs in it and thats it?
Old Aug 13, 2010 | 09:59 PM
RamAir95TA's Avatar
http://autorepair.about.com/od/engin...press_test.htm
Old Aug 14, 2010 | 03:55 AM
perfect
Old Aug 14, 2010 | 09:19 PM
anyone else have their opinion on if i should or not? how many kms are these engines usually good for?
Old Aug 15, 2010 | 10:47 PM
compression in all cylinders where between 175 and 190
Old Aug 15, 2010 | 10:57 PM
RamAir95TA's Avatar
Those numbers are good. I wouldn't hesitate to do a cam swap or equivalent.
Old Aug 15, 2010 | 11:24 PM
rangerguy's Avatar
If it ain't broke don't fix it!!! Good oil pressure, good compression, no major leaks, your good!!
Old Aug 15, 2010 | 11:27 PM
perfect, ill be sending out my money order tomorrow to ai for my cam kit, timing set, and opti.
