tci 3500 super street fighter stall + cam question
#41
yeah you need to measure the gap between the mounting pads and flexplate. very important to do that. you might want to double check so your not too tight. Too tight, and you'll put unwanted stress on the pump and cause it to fail. You want the converter to pull out slightly when it gets bolted.
