Contemplating a 396 LT1 Build for a winter project...
I am new to the idea of stroking an engine so I am learning so please go easy on me here lol, but am I correct?
Also I am looking at prices. I am going to forge it of course, and it COULD be used as a setup for a F1SC or something along those lines later...but for now a Stroker with Nitrous. I know this will be pricey, but its a project and I will be purchasing a seperate block to do this so I am not without a car while building it or if something goes wrong.
Now my next question. Be it 383 or 396, how well will my CURRENT setup work for this? What WILL jive and what WONT? I know the cam and pushrods wont...what else? Heads? Intake? etc
I currently have the LE2 heads with 2.00 int/1.56 exh 52cc chambers, Comp Cams Ultra Pro Mag 1.6 NSA Roller Rockers, and Patriot Extreme .660 Springs.
I have a 58mm TB, and ported intake manifold, LPP LT Headers, 3" Exhaust, SVO 30# Injectors, Walbro 255 Fuel Pump, LS7 Lifters
What else do I need? Should I P&P my heads more? etc.
Thanks for the assist guys.
Have AI/LE port out a set of AFR's or TFS 220 casting, new cam to match, maybe convert over a intake. Depending on the setup you may need to run a shaft mount rocker. Upgrade to 42lb injectors.
Or you could build a 385, have Llyod do everything he can to the heads, new matching cam, monobalde. 37/39 injector.
Also you need to decide up front whether you're going to build a forced induction engine, or nitrous engine... Two completely different approaches there.
You would do well to maximize the setup you have now. You're not even CLOSE to running the number that car can run.
Your choice though, some people keep refining a combo til it performs like it should, and some people keep spending money and going "bigger" with mediocre results.
I am just trying to decide on a few options cause I am gonna be getting quite a bit of money this winter. I plan on finishing my rear end build ASAP, then I want to rebuild this Jasper Block. WAS thinking just refreshing the internals...then started thinking of going forged since I will have it apart...then started thinking stroker...you know how it goes lmao.
I MAY still keep it the 357, and just spend the money on the paint and body stuff like rolled fenders, paint job, etc...**** I dunno! lol
Build the motor for what you are going to use it for, NOW. Not what you "plan" on doing in the future.
To a degree, if your FI will be installed with in the next 6 months after the intial build, ok. I understand but a FI set up is a lot more $$$ and most cannot get to that next level so easily.
Do a 383 with a good H/C set up, good dyno tune and toss a Shot of Nitrous on it in the interm.
ZL1LT1 has some good ideas doesn't he?
