estimated whp? also cam q and what'll it run
These threads NEVER get old!
I'm hoping this set of parts will set me up decent...
What I have:
LPPs
mail tune
3.42s
ram air intake
3200 stall
Ran 13.1 and trapped 103 (guessing 285whp off that)
Installing:
1.6 pro mags
thinner impala gaskets
cam: 230/230 .601/.601 107 lsa
and cleaning up heads
...maybe ewp
Where's the power going to peak at?
WHP? I know the auto/stall will drop it some.
What should it run?
I'm bored. Figured I'd ask. I have my ideas of answers to all this in my head but I'm more than likely wrong.
What I have:
LPPs
mail tune
3.42s
ram air intake
3200 stall
Installing:
1.6 pro mags
...maybe ewp
What should it run?
Power should peak around 6300 or 6400 because of the LSA. You should be making 350-350 and mid 12s in the 1/4. Id either downgrade your stall or upgrade your gears with the 4K. A 3600 would work better with the 3.42s than a 4000
Is that an older Bret Bauer grind by chance?
I have had no personal experience with single pattern cams in LT1's so take this FWIW. I have yet to see an LT1 run impressive times or put down impressive numbers with a single pattern cam and stock unported heads. If it were me I would sell the cam and get something a little more appropriate that has a nice split to it. The cam you have will obviously increase performance no doubt about it but if you want to maximize your combo I would get a different cam, just my .02.
