Single Plane for LT4 Heads
Old Aug 23, 2010 | 02:58 PM
monster81's Avatar
Question Single Plane for LT4 Heads
Well ive searched but couldn’t find an answer. Im lookin for a single plane manifold for lt4 heads thats already been drilled to accept traditional SBC intake manifolds.
I found this Super Vic manifold (part # 2971) (http://www.summitracing.com/parts/EDL-2971/), the Edelbrock website says ‘Super Victor #2971 is for raised port heads. They have a large runner cross-sectional area (3.2 square inches) and highly efficient cloverleaf plenum design.’
Since the LT4 heads has raised intake ports; do u guys think the ports on this intake manifold will line-up with the LT4 heads intake ports?
Old Aug 23, 2010 | 11:50 PM
Wicked94Z's Avatar
just get a standard super vic and get it ported
Old Aug 24, 2010 | 12:23 AM
LTXBOI's Avatar
how is the hood clearence with a super vic or vic jr??i have plans to do it also...
Old Aug 24, 2010 | 01:05 AM
monster81's Avatar
thats what i though but wasnt sure if it works, if u think porting will do ,i might just give it a try ..thax
Old Aug 24, 2010 | 01:18 AM
Wicked94Z's Avatar
I'm not running a super vic yet... piecing the swap together for later this year. From the pictures I've seen, a 3" cowl should work fine depending on what sort of elbow/carb hat and intake setup you run. Just get the EFI super vic and the fuel rails they sell for it...
http://www.jegs.com/i/Edelbrock/350/...oductId=749245
Old Aug 24, 2010 | 01:19 AM
Wicked94Z's Avatar
skip the vic jr and go straight for the super vic. it's hard to get a big enough CSA out of a vic jr without alot of work. your intake porter will thank you
Old Aug 24, 2010 | 06:14 AM
joelster's Avatar
The professional products super hurricane manifold has bigger ports than the victor efi. That super vic you posted isn't drilled for injector bungs.
Old Aug 24, 2010 | 01:14 PM
monster81's Avatar
thats right, its a carbed build
 Michael S. Palmer
Old Aug 24, 2010 | 03:47 PM
Wicked94Z's Avatar
might wanna check the picture again, its definitely drilled for injectors
most of the work on the single planes is in the plenum and dividers. yes out of the box the hurricane is bigger, but a supervic is king of all ported cast single planes unles you're doing a two piece brodix
Old Aug 24, 2010 | 06:56 PM
Bumper Dragin Bird's Avatar
I got lucky and found a guy on ltxtech(casper) who was selling a victor efi that was ported for lt4 heads. I am also doing a carb build and had the injector holes pluged and ground down alil. the machine shop made it so i can run a fogger kit in the injector holes if i wanted
Old Aug 25, 2010 | 12:29 AM
monster81's Avatar
im glad to know that only porting is required to match the super vic to the LT4 heads.
