1st- 2nd gear synchro or shift fork?
Old Aug 25, 2010 | 12:09 AM
ryanosborne's Avatar
Default 1st- 2nd gear synchro or shift fork?
if my rpms are either bit high it grinds very badly going into 2nd gear. and sometimes it doesnt go straight into 2nd gear. i figured the synchro was gone but could the shift fork also be bent? im ordering a rebuild kit for the transmission but it doesnt come with the shift fork.
Old Aug 25, 2010 | 11:25 AM
should i replace the 1-2 gear synchro when the tranny gets rebuilt?
Old Aug 25, 2010 | 11:30 AM
killagt's Avatar
what year is your car ? sound like common on every t56, second gear weak. do some search and decise your self for a rebuilder. sponsor here is a good rebuilder . but do a search and wait for every one else comment.
Old Aug 25, 2010 | 02:37 PM
1994. i was going to order a rebuild kit off ebay and get a local mechanic to rebuild it. i dont have the time to send it out
Old Aug 25, 2010 | 03:07 PM
BlackBird87's Avatar
True but it should go away after being warmed up and it should never be really bad
Old Aug 25, 2010 | 05:23 PM
well its bad and doesnt go away when it warms up.
Old Aug 25, 2010 | 06:05 PM
killagt's Avatar
if you get it rebuild by the mechanic, ask him to buy the kit for you, cause if something happent, he the one need to fix it. my friend been in your situtation and he bought a kit from some where, and let a shop rebuild it for him, few month later, it fail and they blame on the part he order. so make sure he get the part and rebuild it himself.
Old Aug 26, 2010 | 06:10 AM
well,,, i want to figure out what everyone thinks first cause i literally live in the middle of nowhere lol.
Old Aug 26, 2010 | 06:49 AM
z_speedfreak's Avatar
are you sure theres some one qualified to work on it in your area? I tried to get mine done locally first but quickly realized no one had any experience with the t56, the top trans place in my area(90% auto trans) didn't want to touch it and wanted me to get a reman. t56 for $1200(not including labor), at the next place they tried telling me I didn't have a reverse synchro when I told them it was blown along w/ 2nd, and etc etc. finally I shipped it out and had it beefed up for a little more than what the 1st place wanted for a reman. stocker.
personally, I'd send it out and deal with the down time. your shift fork should be fine unless your really hard on it shifting, the rebuild I had done came w/ all new steel shiftforks, also if theres more things wrong with it and you have it done locally you'll be dealing w/ more downtime than if you had just sent it out, or worse it could go un-noticed. Mine needed a new 2nd, 6th and reverse gear
Old Aug 26, 2010 | 12:41 PM
i didnt shift it hard but the previous owner did
Old Aug 26, 2010 | 03:26 PM
yeah the previous owner was hard on my trnas as well, I'd just get a new fork to be on the safe side, D&D has them for $19> http://www.ddperformance.com/shop/pr...th=110_103_119
Old Aug 26, 2010 | 10:09 PM
sounds good
Old Aug 27, 2010 | 11:34 AM
wheres the best place to buy a complete transmission and about how much would that cost?
