Need Advice: Oil in Radiator :-(
Old 09-03-2010, 06:45 PM
Badazz 97 TA's Avatar
Originally Posted by LT1559
When i changed my head and head gasket on the passenger side I torqued it down with 3 passes going up to 65 ft. lbs according to the haynes manual. But when I read on the internet everyone was telling me to do 125 ft.lbs(or somewhere around there i forgot the exact number). What torque specs am I supposed to use? The car ran "okay" with no head gasket leak, but did have an oil leak due from not being correctly sealed at the rear of the intake manifold, it was also missfiring. occassionally the car overheated( i did not let it get past the 3rd tick) but i figured it was due to not properly bleeding the radiator system so i just kept filling it up with coolant thinking the airpockets would soon bleed out by me filling everytime with the car running and bleeder valve open, and i ran like this for maybe less than a month. then the other day i opened the radiator cap and found "chocolate milk".
you only did the passenger side?? how do you know the driver side isnt bad?
Old 09-03-2010, 06:49 PM
AZ2ENVY's Avatar
What head bolts did you buy ? And yes the question is did you only do one side or both
head gaskets ?
Old 09-03-2010, 06:55 PM
LT1559's Avatar
When I first bought the car the owner before me stripped the spark plug hole going into the head on cyl #8(stupid cause it's the easiest one to get to) so i found out the hard way cause it shot straight out and took the threads with it lol. so i bought a set of stock heads and threw on the passenger side temporarily cause i also have a set of ported heads that i'm going to throw in along with a cam, Roller Rockers, Isky .550 springs, longtubes, egr/air delete, etc, etc. I just need the car to pass smog right now lol that's why i just did the passenger side.
LT1559's Avatar
and thanks for the info everyone.
Old 09-03-2010, 06:56 PM
LT1559's Avatar
felpro head gasket and autozone head bolts, i guess i probably went wrong with these headbolts but we all learn from our mistakes
Old 09-03-2010, 07:13 PM
AZ2ENVY's Avatar
I would highly recommend ARP Head bolts .....
http://www.summitracing.com/parts/ARP-134-3701/
Old 09-03-2010, 09:53 PM
Wicked94Z's Avatar
i used autozone headbolts before... never had any issues.
Old 09-04-2010, 01:54 AM
AZ2ENVY's Avatar
True you might have never had issues but why take that chance with inferior products
with such an important part of the build ?
Old 09-04-2010, 02:06 AM
31camaro's Avatar
it not that hard to read the info that comes with the head bolt, stock torque spec is 65 ft lbs, 3 passes, if you are using ARP head bolt go 75 ft. lbs. in 3 steps 25 ft. lbs on every bolt for the cylinder head on that bank, then go 50 ft. lbs again to every bolt on that cylinder head bank, then finally 75 ft. lbs. make sure your torque spec is locked in on your torque wrench, also make sure it is calibrated for accurate torque rating
Old 09-04-2010, 02:08 AM
31camaro's Avatar
who ever told you 125 ft. lbs. dosent need to work on cars especially the general publics, the head of the bolt would snap off before you see 125 ft. lbs
Old 09-04-2010, 09:23 AM
ThreeHonks's Avatar
125 ft-lb!?!?! What is it a diesel?
Quick Reply: Need Advice: Oil in Radiator :-(
