Cam and Heads + Build Question(s)
Old Sep 5, 2010 | 01:32 PM
Xer0ta's Avatar
Advanced Induction setup:
Ai 190cc Street/Strip Heads with new Beehive springs, retainers, locks, 2.00/1.56 stainless valves, ported and polished street/strip manifold work, Ai 226/234 - .569-.570, 110 LSA Cam, ARP 7/16 studs, GMPP roller lifter kit, Ai hardened guideplates, CC Pro-Magnum 1.6 ratio Rockers, Ai ChromeMoly 5/16 x 7.xxx one piece hardened .80 wall pushrods.
Sending in my heads, manifold, TB as cores
assembled and ready to bolt on for 2900 + shipping? I think we have a winning package here for this LT1 Rookie ladies and gentleman.
opinions on this from you more experienced guys?
Old Sep 5, 2010 | 02:07 PM
pyro719's Avatar
Just bolt some ls1 heads on your car. Thats what the really fast guys do.
Old Sep 5, 2010 | 02:12 PM
LSWHO's Avatar
http://WWW.trickflow.com/egnsearch.a...8&autoview=sku
Old Sep 5, 2010 | 02:25 PM
pyro719's Avatar
I still have a hard time seeing those flow #'s out 185cc port
Old Sep 5, 2010 | 04:58 PM
RamAir95TA's Avatar
Step up to the 200cc package and crap your pants.
Old Sep 5, 2010 | 05:53 PM
Xer0ta's Avatar
Default Haha
Actually I was considering that but I still wanna be able to dive the car and enjoy it so the smaller head package seems best. The 200cc package does just scream out "10 second machine" though @_@
Just nice to see a complete top end, right down to the lifters and pushrods, for under 3,000$. Have to mail in my Throttle Body when I send the intake and heads as they say they can "only match your intake to your throttle body if we have the throttle body to use for measurement." Seems common sense to me.
Old Sep 5, 2010 | 05:56 PM
speed_demon24's Avatar
As long as you stay reasonable with the heads they wont affect the driveability, the cam does that. The 190's still have a ton of potential though.
Old Sep 5, 2010 | 06:09 PM
Xer0ta's Avatar
Yeah I can see that. Whats the powerband on that size cam, Ai website is listing 2000-6200 but the people i've pm'd and talked to with it say she'll run strong all the way to 6600 or so. (i.e. a 3600-4000 stall and tune the computer to shift around 6400 at WOT) Than again I guess that all comes down to dyno tuning the motor right. Dyno numbers will show exactly what the combo of heads and cam "pull" to and you need to set your shift point and rev limiter around there for specific applications correct?
God I hope im not answering my own question here.
Old Sep 5, 2010 | 06:18 PM
It would probably be best to talk to the guys at Ai about that. Ported heads will bring the rpm range up quite a bit on topend. My 228 degree cam doesn't even peak till 6400-6500.
Old Sep 5, 2010 | 06:24 PM
Xer0ta's Avatar
Yeah I figure a few emails to Ron and some dyno time after they are on the car should settle that. Just confuses me when a cam is listed as "x,xxx to x,xxx" rpm and than everyone tells me they set shift points 400 rpm over advertised PB Not that I have extensive knowledge of the setup (obvious by now) but it seems with the 226/234 cam everyone says 6400 is the magic number...
Old Sep 5, 2010 | 07:16 PM
slomarao's Avatar
Dont buy any of the edelbrock stuff. Your money will be better spent on porting the stock casting.
Le2 heads, 226/230 cam, ported intake
get the summit 58mm TB & pacesetter headers/borla
Get a yank or vig stall, something around 3200-3600rpm. And the rest looks good, do these small changes and you ll have quite a bit more power for the money spent.
Old Sep 5, 2010 | 07:49 PM
  #32
Xer0ta's Avatar
Yup yup. I've changed my siggy to reflect the changes i've made to my build sheet based on the information you guys have given me. Excellent help you guys I thank you very much!
Old Sep 5, 2010 | 08:17 PM
  #33
gregrob's Avatar
Those Magnum rockers you listed aren't even full roller. Get comp ultra pro Magnums if you want one if the best rockers out there for the money.
Old Sep 5, 2010 | 08:19 PM
  #34
Xer0ta's Avatar
Love the signature lol
Old Sep 5, 2010 | 08:24 PM
  #35
gregrob's Avatar
Yep lol
Old Sep 5, 2010 | 08:31 PM
  #36
Xer0ta's Avatar
I think i got a pretty solid setup in mind now thanks to you guys. Amazing help
Siggy lists it all
