mattcossel29's build thread
Old Oct 1, 2010 | 01:45 AM
mattcossel29's Avatar
Thank you again for all the kind words! I am pressing on!
10/1
Over all tonight was a pretty productive night. I had a few setbacks but all in all progress was made. I was finally able to clean up the intake manifold and get it put back together and bolted on. I also got the accessory bracket cleaned up and bolted it back on again. Got the motor mounts on and dropped it in the cradle. Put the stall converter in the transmission and got that bolted onto the engine. I am hoping if things go as planned it should be going in about a week!
Old Oct 1, 2010 | 01:51 AM
marc97taws6's Avatar
Originally Posted by mattcossel29
Oh for sure! Hopefully I don't look like a fool and end up being slower than you...
Idk Matt, I just might have to get a baby cam to keep up with you
Old Oct 7, 2010 | 04:21 AM
Update 10/7/10
I just buttoned things up getting ready to lift it back up into the car.. Things such as the power steering pump, ac delete pulley, throttle body, headers, fuel rails and injectors..
I also did some touch up painting to the engine bay.
Old Oct 7, 2010 | 03:15 PM
MasterTomos's Avatar
Cool build, nice to see another Iowa guy doin some work! Where in Iowa are you located?
Old Oct 7, 2010 | 08:51 PM
Thanks! I am in Newton.
Old Oct 9, 2010 | 04:45 AM
Big update!
Got all the sensors and little things bolted up and the wiring harness ran, changed out my injectors, and put it in the car and got quite a various things done.. Coolant lines ran, vacuum lines, driveshaft, etc...
Old Oct 26, 2010 | 07:43 AM
It runs!... Well.. It runs again!.. This time with oil pressure..
Battery died in the phone so I dont have any pics or video..
Old Nov 9, 2010 | 01:49 AM
Old Nov 9, 2010 | 02:17 AM
Rob94hawk's Avatar
Nice! I see you put the engine harness on before you put the engine in. How did you get the rest of the harness out of the firewall?
The passenger side looks nice with the touchup painting. Since we have the same color what touchup paint did you use?
Old Nov 9, 2010 | 02:44 AM
We just coiled up the tail that went in through the firewall on top of the intake manifold and fished it through once the drivetrain was in. The harness was completely out of the car as this was a 93/94 swap.
This is what I used on the engine bay and the intake manifold. I used the same brand in Chevy engine orange on the block.
http://shop.advanceautoparts.com/web...ci_sku=7141557
