AI 226/234 results, very happy!
#41
Awesome, I appreciate the offer & kind words. We've been so busy over the past year that our website and results list really needs an update. I've also created a youtube channel, so everyone researching will have a large selection of results, sound clips, etc. from you guys, the actual customers.
http://www.youtube.com/AdvancedInduction
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
On heads, even our 190cc CNC'd GM LT1 will outperform the as-cast 21 deg head. As the majority of your $ isn't going toward the casting itself, it buys you superior machine work, components, and more consistent results. I like the 21deg TFS head & we've got a couple CNC'd versions of it. At the same time, there is not much that is appreciably better than the factory casting when it comes to most moderate street oriented applications. In the end, the result will be a function of the work applied to the casting, and not typically the casting itself. ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Haha thank you!
#42
I really need to finish up my camaro,l got preety much the same set up as you do but with a k&n intake and hooker catback, I ran into problem after problem with my setup while trying to get it tuned and finished then i gave up for a bit. I'm still rocking the 2.73 gear and i know that is whats killing my setup. Ran it at the track once and was still in 2nd gear going through the traps.
Congrats on the good setup!
#45
