electric water pump install.
Old Sep 16, 2010 | 02:37 PM
redhot lt-1's Avatar
Default electric water pump install.
ok i`m doing an electric wp on my 96 lt1 i`ve searched wide and far for some extra info on the wiring to the lt1 wiring system i know i need to use a Borg Warner R3151 Coolant Fan Relay but what wire in the fuse box to tap? any body got a clue?. i know that someone has done this and post an article about any help would be good. thanks.
Old Sep 16, 2010 | 02:44 PM
RamAir95TA's Avatar
http://www.lt1engine.com/tech/electr...r-pump-wiring/
Old Sep 16, 2010 | 02:51 PM
defaultexistence's Avatar
https://ls1tech.com/forums/lt1-lt4-m...-lil-help.html
Word of advise....there is no need to remove the gear sticking out of the timing cover..leave it alone..just incase you have an emergency and have to throw a sock WP back on.
