LT1 turbo what plugs should i run?
i tried the ar94 plugs with a .028 gap its running real good now. i geuss we'll see how it holds up under the higher boost. if it still misses ill have to change the gap smaller again
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
so i guess the real question is the ar94 plug cold enough to run 17psi i also have sno performance meth injection and controller to run more with more boost. im gona run blue washer fluid in it.
