Driver side header on, question. Pacesetter guys come in.
Driver side is on, pretty much bolted on only a couple need better tightening after I get a better wrench. Anyways....the collector on the header is slightly above the floor bump maybe a 1/2" give or take. Is this normal? If its not normal what is that cause, motor mount? I would think it would sag if it was mount.
I have real pics if needed but will be quicker to draw a crappy pic... lol
Where did you buy them? I'd strongly consider sending them back for another set if possible. Most vendors would not have a problem with that. Also, I'd think a sagging motor mount would make it hang lower...not be up to high so with your pics, they shouldn't give you a problem at all.
Might work enough to clear it. but i would get all the bolts in the head and tight befor trying to pry on it, dont want anything snapping off. very odd...how is the clearance on the steering colum? id say if the steering colum is bad clearance as well then maybe you will have to send it back.
