Will a bullet muffler soak up HP?
Old Sep 19, 2010 | 07:57 PM
Quick94LT1's Avatar
Question Will a bullet muffler soak up HP?
How much if any HP does a bullet muffler welded in the I-pipe of my magnaflow cat-back soak up? And what size bullet do I need and what brand is the best? Will it totally quiet down the exhaust? In just looking to eliminate the rasp during WOT. I already have a FM merge on my off road y-pipe.
Old Sep 19, 2010 | 08:49 PM
hitmanws6's Avatar
A bullet shouldn't soak up any hp, its straight through. A magnaflow bullet should help a lot, adding cats would work as well
Old Sep 19, 2010 | 10:27 PM
01ssreda4's Avatar
There are basically two different kinds of bullets. Chambered like powersticks and stainless werks, and glasspacks like dynomax, summit brand, etc etc. Both kinds should flow really well and will tone down the exhaust slightly based on the length of the muffler. Listen to as many sound clips as you can to decide which is best for you.
Old Sep 20, 2010 | 06:39 AM
Wicked94Z's Avatar
just get a cheapy dynomax bullet, it'll cost you no more than 1 or 2 hp
Old Sep 20, 2010 | 08:28 AM
01ssreda4's Avatar
You're a fool, it wont cost anything bc the Dynomax is a perforated core design. No internal obstruction. Flows as much as a straight pipe.
Old Sep 20, 2010 | 08:37 AM
n2oblkz's Avatar
I use to have a Dynomax bullet in my I pipe, but swapped it for a Powerstick Bullet, it's a true 3 inches through and doesn't neck down so there shouldn't be a loss. It gave a deeper tone to my cat back and got rid of most of the rasp.
Old Sep 20, 2010 | 09:15 AM
speed_demon24's Avatar
No they don't. It'll flow close to a 3" pipe but it will still be down a bit.
Old Sep 20, 2010 | 09:21 AM
Wicked94Z's Avatar
so... i could build my entire exhaust system out of preforated core mufflers, and it would flow as good as the 4" pipe i have on there now, but be way quieter?
Old Sep 20, 2010 | 09:25 AM
draggin97s10's Avatar
Old Sep 20, 2010 | 12:00 PM
harner's Avatar
Try it and post pictures on the Internet.
Old Sep 20, 2010 | 12:34 PM
quik95lt1's Avatar
i race my car with two of the 3" dynomaxes off of my headers......quiets it down alot so i dont go deaf and the car doesn't loose anything.......they actually help me because it eliminates any reversion on my WB02's on the XFI
Old Sep 20, 2010 | 12:41 PM
wrd1972's Avatar
Dat would be fugging da' bomb man.
Old Sep 23, 2010 | 01:50 PM
The LT1 That Could's Avatar
I ran near identical ETs open header vs. x-pipe setup with 2.5" dynomax bullets.
Old Sep 23, 2010 | 02:07 PM
WS Sick's Avatar
Look Into the glasspack and stay away from the ones that the perferated holes go into the flow path, very disruptive and comparatively restrictive, Dynomax perferations go out away from the flow.
