leading factors to fuel pump death
I could have been like puck said above with some kind of contamination. Make sure the tank is clean and you replace the sock and do all this in a clean area and working surface. I ran a walboro 255 for 3 years with no problem then I had to swap it out for an A1000 cause the new motor was too thirsty for the 255 ........i had the racetronix kit.....also for what its worth......my wiring did go bad on me on the walboro once.....i lost the ground wire into the tank it went bad in that little yellow bulkhead connector......a good sign of this is you will see the fuel level gauge peg to full......also did you check the relay? make sure theres power and ground in there before you go dumping money into a pump....
Thanks for the help guys it ended up being the connection from my chassis to my pump it primes and car runs well again
http://www.youtube.com/watch?v=PqnQ2...e_gdata_player
